Category : Fanuc Turn
What to do Next?
Correct
Incorrect
Don’t say I didn’t warn you.
G0 X21. Z3.
G97 S1200 M3
G76 P010060 Q20 R.02
This thread has a core diameter of 16.96 (X16.93) the thread depth is 1.535 (P1535).
Wrong as Below
G0 X19.95 Z3.
Well now’s the time.
G0 X21. Z3.
G97 S1200 M3
2.5 x 1200 = 3000
Strange Behaviour
Maybe you had a pitch error.
G0 X21. Z3.
G97 S2400 M3
2.5 x 2400 = 6000
Eat more fish.
You know that old book that you use to prop the door open.
