Basic Turning
Basic Turning
G96 Hamsters Large wheel Small wheel
G97 Speed In RPM
G97 S1500 M3
When drilling  a hole you are on the centreline of the machine so you just want plain old simple RPM.
G96
G96 S200 M3
Basic Turning
If the tool was positioned  at a 100mm diameter it would be as if the tool were able to run around this diameter at  a speed 200 meters a minute.
Basic Turning
Neeeeeoooooooowwww
G96 G97 hamster on a Wheel
Anyway I did and his name was Harold Wilson (British Prime Minister at the time).
Basic Turning
G96 G97 all about hamsters
Harold Had G96
Harold Was a Clever Bastard
200 / .6864 = 291
Manual Lathe
cnc turning basics
G50 Warning
Watch the video
Basic Turning
G96 and G97
G96 Whoopee It’s amazing
So use G96 for everything.
Except for:
  • Drilling.
  • Tapping
  • Threading (Screw cutting)
  • Cutting the Lawn
New CNC Machines, Explore the Old One First
New CNC Machines? Make Use of What You Already Have
New CNC Machines
Before you buy any new CNC machines or computer systems checkout what you already have you might be surprised at what you can do. Breath life into the old beast.
Before buying New CNC Machines is there more you can do with the old one.
Mori Seiki Lathe
Investment
About 10 years ago my big gripe with companies when looking at increasing productivity and improving production methods, was that there was little investment in new technologies.
New CNC Machines represent a massive investment
Mazak Integrex Lathe
Now You Have New Machines
I think that now things are a bit different companies have invested in New CNC Machines and computer systems, although there is still room for improvement. Being the grumpy old ageing failed rock star that I am, my moan now is that the technologies that people have invested in are not being used to their maximum capabilities.
New CNC Machines
Bright Ideas
These are some of my suggestions and your MD will love the fact that they all cost little or no money:
  • Read the manuals on your CNC machine just the first few pages (not the boring health and safety shit, the next bit) bet you will learn something you didn’t know.
  • Now, about that probe in the carousel (covered in swarf, shit and coolant) that no one knows how to use. Learn to use it. Come on now there are loads of idiots like me posting free videos on this stuff. Once you use one I will guarantee your life will never be the same.
  • Check out the settings on your Haas machine (I can always get people excited about what these can do) look at the Haas tips n tricks page on their website. You will learn loads of stuff to impress your mates, not at the pub though please.
  • Make sure you are using the latest version of Edgecam (or your chosen CAM system). Edgecam and all software is evolving rapidly and you could be really missing out. If you have a software maintenance contract then you’re pouring money down the drain by not using the support.
  • Try to make a point of learning something new every day. (I am 86 and I still do) write them all in a book so you can look back and use your ideas.
That’s Not All
Check out the options on your machine. Maybe you have some really cool options you didn’t even know about. Might even be worth shelling out a few quid to buy some extras.
  • Rigid tapping.
  • Through spindle coolant.
  • Higher RPM.
  • Macro B.
  • Peck Tapping.
  • Extended work offsets.
  • Extra editing functions.
Watch These Videos
Copy a program on a Fanuc 18i
Copy and paste on Fanuc 18i
Oh and There’s More
If you really want to spend money I can help you with this I’ve already spent nearly all of mine. .
  1. Consider buying a touch probe, they save hours in setting time.
  2. Auto tool measurement probes can be used to set tools automatically. You will also be able to do in program checks for tool breakage etc.
  3. Add Macro B to your Haas or Fanuc control for loads of extra features.
  4. Add a speeder unit to increase maximum RPM.
  5. Consider adding a 4th axis to your vertical machining centre this will give loads of extra capacity and flexibility. Not cheap but well worth it.
But Most Of All Get Us To Train You
Please let me know how this goes, enter your comments below.
Contact me
  • Siemens Sinumerik
Edgecam Version Update Now
Edgecam Version
Make sure you are using the latest version of Edgecam. This software is rapidly evolving. You can spend a small fortune on tooling and CNC machines. Your CAD CAM system can make you fire on all cylinders.
Edgecam Version
Thanks to MTS Motorbike Tire Shop
Edgecam Training from the CNC Training Centre.
Edgecam maintenance contracts represent very good value for money and they entitle you to Edgecam support.
Edgecam support is the best.
Edgecam Version
Contact us if your interested in buying Edgecam
Other Edgecam Stuff
Layers in Edgecam
Siemens Sinumerik Training
Modal and non modal G codes
Let Me explain
We all know that programming can be complicated. So let me explain to you how it all works. This article explains the real meaning of Modal and non modal G codes.
Modal means that once a command is issued it stays in the control.
How Can you Actually Use This?
If you issue a G0 or G00 command the machine is in rapid and you do not need to re-state it.
Rapid means all motors are flat out, like a teenager in a Ferrari.
Every move from then on will be a rapid move unless you tell it otherwise. The G code that changes it must be in the same group. For example G0 G1 G2 and G3 are all in the same group a bit like The Beatles used to be.
The other day I was talking to  a “young person” who hadn’t even heard of the Beatles. I mean fuckin hell, am I really really old or are they doomed to be forgotten?
CNC Machine Training Classes
Category : Training
CNC Machine Training Classes now running at the CNC Training Centre
Beginners
Setter Operator Beginners Turning
Setter Operator Beginners Milling
These two courses are designed for beginners who want to learn how to set and operate a CNC machine and are for students with very little engineering experience.
 Learn to Programme
Learn To Programme Turning
Learn To Programme Milling
If you already work on a CNC Machine but you want to learn to programme then the two courses above are for you.
Absolute Beginners
I have added these courses which are for students with very little engineering experience. They cover the basics of milling and turning in preparation for learning to programme.
Beginners turning
Beginners Milling
They are two day courses but pack a lot in, covering tooling and measuring instruments. I am drawing from my vast experience in industry, on the coal face as it were, and knowing the very basics skills that are needed by a CNC operator before he begins to learn about programming.
The New CNC Training Classes and Courses focus very much on the basics giving a solid understanding of the nuts and bolts of CNC programming on an ISO Fanuc Haas type control.
The Story
I am going to ramble on, because I always do, but it made me think of when I worked with my dad many years ago. My dad was a brilliant old school engineer and he worked for Alfred Herberts from boy to man, apart from a brief period in the RAF.
New CNC Training ClassesHe got made redundant and had his pension robbed when AH finally went bust. I was running an engineering company so it seemed obvious to have him working for me.
I learnt so much from my dad about the basic principles of machining (this is the link to the training courses) albeit tenuous. His claim to fame was that he worked the first Cri Dan machine. This was an amazing innovative machine that could hold it’s own, until fairly recently, against a CNC lathe for high-speed threading. There are still a few about now.
New CNC Training ClassesMy dad often joked that he could offhand grind a 1/16 of an inch drill and read a steel rule to a thousandth of an inch which I am sure was bullshit although I would never dare to say. I remember we were trying to turn and bore some motor bodies on a Mori Seiki lathe and we could not get them round. Anyway he told me to weld up some jaws so that they would fully envelop the part.
CNC Machine Training ClassesCNC Machine Training Classes
Basically it had nowhere to go it was like a big collet and it worked. But there was another lesson to learn. Our inexperienced inspector was trying to measure roundness with a micrometer which I am sure you all know cannot be done.
An argument ensued and profanities were exchanged. We ended up buying a Talyrond roundness checker which is the correct tool for the job.
As it happens the same thing cropped up in a customer’s only a few months back. I caught them trying to measure roundness with a micrometer. Back to basics again.
These days I have a much better way to prove my point than shouting and swearing and it’s cheap 50 pence to be precise.
I threw them a 50p piece (UK Currency) or even a 20p for the real cheapskates. “Is that round” was my question. They laughed
“Here is a micrometer now check it for roundness”.
Mmm it’s dead round when you check it with a micrometer.
The smart arses amongst you will know that a 50p piece is an “equilateral curve heptagon“. And it measures the same across any two points you care to choose. It proves that you can’t measure roundness with a micrometer.
I won’t be teaching you about roundness on these courses ,that would be silly you already know, but if you are interested in learning basic CNC Programming for a Lathe or Milling Machine look no further.
The New CNC Training Classes focus very much on the basics giving a solid understanding of the nuts and bolts of CNC programming on an ISO Fanuc Haas type control.
See all The Courses
