Tool Offset Measure Button Haas, Useful or Relic?
Tool Offset Measure Button on a Haas Machines, Useful or Relic?
Call David: 07834 858 407
This article is about the Tool Offset Measure button on a Haas machine.
Tool Offset Measure
I first worked on Haas Machines around 1996. The most amazing thing about Haas machines back then was the price. They were cheap, very cheap. At that time the cheapest CNC Machines were like the cost of a diamond studded jockstrap. But the Haas, well as I said it was cheap.
Everyone thought they were made in some far flung country by Santa’s Elves being paid the minimum wage and fed on reindeer shit.
Actually they weren’t. The reason I’m told they were so inexpensive was because they kept the specification of each machine the same. This made them simpler and cheaper to produce.
I fell in love with those early machines and they certainly earned their keep. The control was like a Fanuc that had been given steroids and a rocket up it’s arse for good measure.
Giving People What They Wanted
It was like someone had heard all my criticisms of CNC Machines and granted my wishes
The way that we trained people in those days was to use the tool offset measure button.
What you did was you touched each tool on the top of the component and pressed this button.
(Sorry about the shit picture couldn’t be arsed to find a better one)
It duly recorded the offset value for you.
So what you are doing is recording the distance from the end of the tool at its zero return position to the top of the workpiece.
Tool Offset Measure
This gives you a minus figure the size of a compulsive gamblers bank balance.
Problems
Ok so this works well but there are two problems. Actually no there a three.
  1. You can’t use a tool presetter.
  2. You can’t roughly check this figure by getting a ruler and checking the tool length.
  3. (And this is the big one) when you set a new job you need to do it all again.
Now I could be being really stupid here, and if you know me you are probably saying “well he is a bit of a dick”. Anyway from that day on I’ve avoided this button like Donald Trump avoids wind machines.
A couple of weeks back, when my restraining order was lifted, I was allowed back on a Haas machine to do some training.
They say you learn something new every day well this day I was about to learn about setting 64.
Tool Offset Measure
What this setting does is it allows for whatever work offset you are in when you press the Tool Offset Measure button.
Tool Offset Measure
So what you do is you get your setting block and you touch your spindle nose on it (I used a 6 inch block of slips).
Tool Offset Measure
One of these is even better.
Tool Offset Measure
Then set this in a work offset that you don’t use like G59.
Offset Is Actual Tool Length
  • So when you want to measure a tool.
  • Call out G59 in MDI.
  • Touch the tool on the top of the block.
Tool Offset Measure
Press the button
Tool Offset Measure
And guess what you get the actual tool length. Tool Offset Measure
If you use a tool presetter just tweak the G59 Z figure until it ties in exactly with your tool presetter.
Or call us on
Reposition Haas  Mid-Program
Piss easy.
Reposition Haas
Same Shit different Day
Here We Go
Reposition Haas
Reposition Haas
Do whatever you want to do.
  • Inspect the part.
  • Blow the hole out.
Now go back into memory mode.
Press Cycle Start.
Reposition Haas
Then axis.
And bang away you go.
The program continues.
Mazak Programming Tutorial
Mazatrol Training Onsite/Offsite
CNC Training Centre offers training on all Mazak Machines this article includes Mazak programming tutorial (VFC and TPS)
Mazak, How It All began
Saddakichi Yamazaki  started making pots and pans in 1919 in a place called Nagoya in Japan.
He went on to mat-making and then woodwork machines. During the 1920’s they started making lathes.
World War II
The company were part of Japan’s industrial buildup during World War II. Like the rest of Japanese industry they were humbled by the outcome of the war.
Yamazaki was revived in the 1950s and 1960s by the founder’s sons. The company went from strength to strength and in the 1980s a manufacturing plant was built in Worcester in the UK.
Mazak Training Mazatrol Training
How do you get from pots n pans to CNC Machines?
Mmmmm
Here is a nice old Yamazaki
I remember going to the Hamburg engineering Show circa 1982 with my old boss and we actually met Teramatsu Yamazaki.
Well I think that was his name I know they called him Tel which we found quite funny at the time. They had this raffle and were giving away these really expensive vases as prizes it all seemed a bit strange at the time.
Oh and he had his own personal magician walking around with him. I’m not joking, a playing card would suddenly appear out of his pocket or some such thing. Weird but a lot of fun.
Anyway they made us very welcome and we bought our first Yamazaki.
Just shows how old I am being able to remember when Mazaks were called Yamazakis.
Early Mazatrol T1
mazak programming tutorial
I remember that you had a choice of Fanuc or Mazatrol as a control. My boss decided to go for Fanuc although I wanted the Mazatrol. (I still love playing around with anything new)
Having seen the demonstration I was absolutely knocked out. It was streets ahead of anything else, fully conversational.
It calculated feeds and speeds and you didn’t need to know any G Codes, M Codes absolutely none of that shit. Good graphics to check the tool path.
Oh did I say it picked it’s own tools too?
Anyway next machine we got we had Mazatrol and I have loved em ever since.
Mazak Programming Tutorial VFC
VFC (Very F***ing Clever)
Contact CNC shopping for spares The control panel was and still is nice and easy to use.
It had this great feature called VFC and when asked what the button was the engineers would always reply “Very Fucking clever”.
Actually it was quite clever (and still is).
The irony here is that I spelt the word clever as cleaver so I am definitely not VFC.
So what you did you would run a face mill or whatever and as it was cutting override the speeds and feeds to your optimum values.
Here Comes The Magic
One press of the VFC button (not to be confused with the KFC Button) and your program would be updated to the new feeds and speeds.
Oh something else
I love showing people this when I am doing Mazak Training Mazatrol Training …………
Mazak Programming Tutorial TPS
Mazatrol VFC Button and TPS Button
Yea that button above it (TPS) pretty cool too. It stands for Tool Path Store by the way.
And that is what it does.
Right imagine the scenario, you have a grooving tool happily doing its business and you want to stop the machine and see what’s going on. Or maybe it just broke the insert!
You press your feed hold button (That’s the red one).
Your machine stops.
You then press TPS and move the X axis. Press TPS and move the Z axis and so on…..
You can now change the insert if you need to.
More Mazak Magic
Move back into the AUTO mode. Ok now when you Cycle Start the machine it remembers this path, follows it and does not break the tool, it just continues where it left off.
Oh and There is More
Whenever I get involved in Mazak Training Mazatrol Training the one thing that impresses me most is this.
Once you call up a tool then the offset becomes active. First time I used a Mazak with Mazatrol I thought it was amazing.
This applies to Lathes and Machining Centres.
That means if you want to turn a diameter you can just move the tool with the hand-wheel to the diameter you want and turn.
On a machining centre it makes setting Work Offsets a doddle (That means easy).
So simple, so obvious, you’d think everyone would do it!!!!!
If you require training on any Mazak machine or control then call the CNC Training Centre and we will be able to help you. We pride ourselves in helping people to get the most out of their CNC Machines.
Be honest how many buttons on your CNC Control have you never used or maybe have never understood?
Well………. now’s the time to start learning.
Here is a video on TPS (Tool Path Store) I left it till last cos I knew you wouldn’t be arsed to read my post.
Fanuc G73
Fanuc G82
