This article is about using G10 on a CNC Lathe to set the work shift or work zero offset as it is known on a Haas control.
If you have ever used Mazak machines you will know that when you call a program the work offset is kept with it.
Obvious really……
I mean if you were teaching your dog or your cat to program a CNC Lathe and you told him that he had to reset the workshift every time he called a new program what would he say.
I mean nothing really but he’d probably give you a strange look.
But you can do it on a Fanuc control or on a Haas control.
You just put this………………….
G10 P0 X0 Z-98.1
Using G10
So you would put that at the head of your program and it would change the work shift screen as above.
Advantages
No need to set workshift everytime.
Automatically sets X figures so there’s no chance you could alter it by accident.
Well there is a slight catch.
It’s obvious really but from now on you can only change the workshift from the program.
If you altered it on the workshift screen it would just change back when you run the program.
Now I know your not stupid enough to do that but I bet the bloke on nights is.
The Big One
When you restart a program you must remember to read this line.
Imagine if you tried to re-run the threading tool after altering the G10 you would just jump to that tool and run it. (Your new offset wouldn’t work)
Therefore you must remember to make the control read it in before running any tools.
Now the clever bastards will have a solution to this.
(This songs hilarious by the way)
What you could do is use a subprogram, if you had one for tool change position you could dump the G10 there.
That way each tool would read it.
Oh yea and it’s probably a bit more tricky to alter as you can’t use input plusUsing G10
So you have to revert to mental arithmetic.
Ok So Why Do I Need All This Crap
Do you use the same chuck day in day out?
Do you keep the jaws for each job?
Well if the answer to these questions is yes, your workshift value is the same every time you set up this part.
Do you really want to reinvent the wheel?
Setting the Workshift (Fanuc CNC Lathe)
Category : Beginners Fanuc Turn
workshift
This article is about the Workshift on a CNC Lathe with a Fanuc control.
As a beginner one of the first things you will need to learn is how to set the workshift.
The workshift is an adjustable figure that tells the control where the work zero is.
It defines the relationship between the turret and the workpiece.
Workshift
So we have a programme for our part on a our CNC Lathe. Let’s assume this programme is perfect with no errors.
But at the moment it’s just a part floating around in space.
Workshift
You have measured the tools using cut and measure or a tool presetting arm. You also need to tell the machine the radius of the cutting tool tip and its virtual nose position.
Workshift
Tool tip radius and virtual nose
So now all the machine needs to know is where the workpiece stock is. That’s where the workshift comes in.
WorkshiftTool Presetting Arm
The setting of the workshift will vary from one machine to the next but just think about this logically.
1 You have a program.
2 Your machine knows where your tools are in the X and the Z axis.
So now your machine needs to know where the workpiece is in order to complete the jigsaw puzzle.
To do this we need to set the workshift.
With regards to the X axis this never changes because the centreline of the machine is always the same.
Just Worry About Z
Sooooo this is just about Z.
The way we do this is to effectively tell the machine where the tools are in relation to the workpiece.
First you need to call out a tool and its offset.
T0101 (Call tool one and offset one)
You could do this in MDI
Workshift
Fanuc MDI Screen calling tool one and offset one
Bring the tool to the front face of the component. If you want to machine metal from the front face then you would position the tool slightly behind the front face.
You could even start the spindle and machine the front face. That way you will know you took off the right amount of metal.
Workshift
Machine the front face when setting workshift
(You can use any tool for this provided it has been measured and you call its offset)
Cursor to the Z underneath (MEASUREMENT) on your workshift screen.
Workshift
Type in 0 then press INPUT
The Z SHIFT VALUE will change.
If you want to you can input zero into shift value on the left to reset it before you start.
I like to do this when I am setting the workshift because you can clearly see the new figure when it goes in.
My screenshots are from newer Fanuc controls. Even if yours is an old banger it will be much the same.
New CNC Machines
Be very careful not to set anything in the X figures because it will completely mess up your X axis position. This could leave you in deep shit.
It is always good to note the X figure even if it is set to zero.
Workshift
This X figure can be used to set the centre-line for your drills and centre cutting tools so it may not be zero.
Mine is set to X270. which is the centreline of my machine. So if I am using a drill or any tool that works on centreline then I only need put zero in the X offset.
Be careful before changing this if you have a tool measurement arm as it will alter all your X figures. You will need to re measure all of your tools.
In the table above tool 9 is a drill and because my workshift is set to the centreline (X270.) I would input zero in the X offset geometry.
Otherwise you would have a standard figure that you put into X for all your centreline tools.
On my machine it would be 270. but it usually ends up at something close like X270.106 which is hard to remember.
I often see this figure written on the side of the machine in felt tip pen for operators to remember.
If you do have a figure in the X it is really important not to change it. I would recommend using G10 in all your programmes. That way you can always be sure this figure is correct.
(G10 is a way of entering your offsets and workshift from the CNC Program)
In the program above it is the G10 P0 X270. line. The P0 tells the control to write to the workshift.
This way even if you fuck up the X position the control will just ignore you and keep writing the correct figure in at the beginning of the program.
Please note I am not putting anything in the Z for the G10 as I don’t want this updating. You can do this if you want, but you need to remember that you can now only alter the Z from the G10.
Testing The Workshift
Once your workshift is set you are ready to prove out your part.
You can test the workshift in MDI if you wish.
T0101;
G0 Z0;
Make sure to override the rapid moves (not 100%) and look at
DISTANCE TO GO
If when you run your program the front face of your part does not clean up or you feel you are taking too much off then the workshift will need to be altered.
Note
Changing the workshift moves all the tools together. I does not change the relationship between the tools.
How to Alter The Workshift
Workshift
Always use + INPUT as this will add the value to the present value.
If you use input it will replace the figure and now your in trouble.
How to Adjust workshift
Be Careful Not to Alter X
Siemens Sinumerik Training
Using U To Program Taper CNC Lathe
I recently wrote an article on the use of incremental U and W on a CNC Lathe for incremental programming.
I must be honest I didn’t have that many creative uses for it.
Anyway when I posted it on Linkedin I did get some interesting replies and comments. I was surprised to see how many people do use incremental U and W.
incremental U
About a year ago I was working at Gardner Aerospace and we were struggling to get rid of a taper on a shaft we were machining.
Not a particularly difficult job other than this pesky taper we kept getting.
It was something like 30mm diameter by about 140mm long. We were making it on a new Haas ST lathe we struggled to hold the size which was about plus or minus .02mm and were getting a taper too.
I noticed that when we programmed a taper it was easy to make a mistake.
incremental U
The above program would take the size .015 less.
incremental U
When it came to changing the taper again the calculation had to be made. I suddenly had a brainwave and realised we could program it in incremental by using a U figure.
incremental U
The great thing about doing this is that you can see exactly what taper you have and it’s really easy to modify.
The other thing is that the figure is always going to be small so it’s easy to spot mistakes.
I got so excited I even made a video.
G74 Drilling Cycle With G96
Category : Fanuc Turn Mazak Turn
G74 Drilling Cycle with G96.
On a CNC lathe G96 is used for most machining. It was amazing in the old days when we suddenly discovered G96.
Because you are using a constant surface speed the metal cutting is consistent so you get a great finish.
The Black Art Of CNC Programming
CNC Programming was a bit of a black art back in the old days and generally speaking we used G96 for everything except for screw cutting and drilling holes on centreline (G74 Drilling Cycle).
When CNC Programming a drilled hole you would always use G97, (this means the speed is in RPM).
If you were to program for example G96 S50 M3 and then rapid to X0 and Z3. ready to drill a hole the machine would just go to its maximum RPM. This would be the speed you set in your G50. (The G code used to restrict the speed.)
Oh by the way that 50 meters per minute is for a B & Q drill.
Don’t get me wrong I love B & Q products but HSS drills are not for grown up engineers they are great for metal work classes at school and making a coffee table for the misses but it’s time to join the big boys and spend some money.
I Digress
Anyway the machine would calculate the speed at its current diameter. So at zero the spindle would always be flat out.
So you could say G96 is pretty useless for a drill.
But you would be wrong!!!!!!
Take a look at this bit of code.
G74 Drilling Cycle
The idea is to send the machine to the drill diameter. Because the machine is in G96 it calculates the correct speed. When you then issue G97 it fixes the speed. Now when you move to X0 it has the correct speed.
Let The Machine Do What It’s Good At
Mmmmmmm… So all you need to do is send the drill to its diameter and the machine does the arithmetic.
Let the machine do what it’s good at and you do what you’re good at.
What are you good at by the way?
Threading is the same if you were machining an M20 thread at 100m/min calculate the surface speed.
(This is the quickest way I have seen)
20/314.2 =.06365
100/.06365 = 1571 RPM
You could do the same thing let the machine do it’s shit.
Rapid to the diameter of the thread then program G96
G0 X20. Z5.;
G96 S100 M3 (Start Spindle at 100 metres per min);
G97 (This will swap to RPM and clamp the speed at the correct RPM);
X21.;
G76 P010060 Q20 R.02;
G76 X16.93 Z-25. P1534 Q485 F2.5;
ETC
So with this bit of code you can get the machine to calculate your speed.
D01 END1 Macro How does it work?
Category : Macro
D01 END1 How does it work?
Someone said to me the other day to “why don’t you just do one”. In fact people often say this to me, even complete strangers. I was forced in the end to google it.
Anyway having researched it at length I can safely say it’s not a term of endearment. It actually means “fuck off”.
Now in macro programming it all takes on a different meaning. If you ever programmed computers back in the 1980’s then you’ll remember BASIC
(Beginner’s All-Purpose Symbolic Instruction Code)
This was a computer language very similar to Macro programming. Mmmmm not come far have we?
Anyway that’s where this language originates. Often known a Spaghetti programming. A pejorative phase to describe this type of programming used mainly because you can be hop skipping and jumping all over the program with GOTO statements and all sorts of confusing shit.
You have to be very disciplined with this type of programming and add loads of explanations. You must space the code out in neat chunks.
Although crude, macro programming has some great uses.
Oh and it adds real functionality to CNC programming.
D01 END1 What is it then?
This is a kind of loop and is best explained in an example. My example is a macro that will drill a grid of holes. The user states the spacing in X and the spacing in Y. Also the number of holes in each direction.
Now I know the smart arses are saying “fuck me, doesn’t he know there are cycles that already do this, yawn yawn”
Well actually I do.
I also know that the wheel was invented 3500 B.C. but the wheel can be used for demonstration which is what I’m about to do.
Demonstrate grids that is not wheels.
First of all this is just drilling one line of holes I’ll then go on to complicate the shit out of it by doing a grid.
First of all I drill one hole at X0 Y0, or whatever I want as my first  position. The G202 has two parameters W and X.
W is the number of holes along the X axis.
X is the width between holes.
So this will give me 6 holes 10mm apart along the X axis.
I have aliased G202 to program O09011 which is my macro. Here’s how you do it in case you forgot.
This is program O9011
D01 END1
The line WHILE [#23 GT 1] DO1
Tells the control that as long as #23 is greater than 1 to go around the loop.
It’s now looking for END1 which corresponds to D01 and it whizzes around the loop.
You can have loads of these.
The END must match the D0.
It could be D02 & End2 the choice is yours. The D02 is just the name it’s nothing to do with how many times you go around the loop.
Just make sure you don’t get mixed up else you will have a nightmare trying to sort them out.
Each time it goes around the loop it checks the condition in the statement.
The line #23 = #23 -1 will reduce #23 by one each time it goes around the loop. (Eventually #23 will not be greater than 1 and the control will escape the loop and carry on)
The next line moves X incrementally (G91) by the amount stored in #24 (this was the X value you put in the G202). It drills a hole because the G81, stated in the main program, is still active.
The control is then put back into G90 (Absolute) as a safety measure.
Read this article for more on G and M code aliasing.
Now Lets Complicate Things
OK so you understood that?
Good now lets completely fuck it up.
D01 END1, This is the complete program.
First of all I drill one hole at X0 Y0, my first position same as above.
The G202 now has four parameters D,W and X, Y
D is the number of rows in Y.
W is the number of holes in X.
X is the width between holes along the X axis.
Y is the depth between holes along the Y axis.
So this should give me 6 holes 10mm apart in the X axis and 6 rows of holes 10mm apart in Y.
(A grid of holes)
More D0’s and Ends
Now we have D01 END1 inside D02 END2.
D01 END1
So……… the D01 END1 is the rows of holes across (X Axis).
The D02 END2 s the number of rows (Y Axis).
Now lets break it all down.
O09012 (Drill Grid of Holes)
G103 P1 (NO BLOCK LOOK AHEAD)
#100= #23 (Store W Value)
The line above puts #23 which was the W value into #100. This is because we are going to need it again when we go round the D01 END1 again. This loop reduces it down each time it goes around, so it needs to be restored.
WHILE [ #7 GT 0 ] DO2 (DO LOOP)
The line above is the condition that allows it to keep going around the loop as long as #7 is greater than zero.
WHILE [ #23 GT 1 ] DO1 (DO LOOP)
#23= #23 – 1 (COUNTER DECREASES BY ONE)
G91 X#24 (Drill a Hole)
END1
The D01 END 1 above is one row of holes once the condition is satisfied it escapes the loop.
#23= #100 (Restore W Value)
Remember we saved #24 in #100. you need to set this back to it’s original value because the loop above reduced it down to zero.
#24= – #24 (Reverse X)
This is to make the X move in the opposite way to make the path zig-zag. This will make it toggle between plus and minus.
#7= #7 – 1 (COUNTER DECREASES BY ONE)
The above is the counter for the rows. Number of rows was in D (#7) so wee need to reduce this number as we go.
IF [ #7 EQ 0 ] GOTO1
G91 Y#25
N1
This little bit of code above is for when we get to the last row of holes we don’t want the Y move as we have completed the grid.
END2
G103 P0 (RESTORE BLOCK LOOK AHEAD)
It looks like this.
So there you have it. I hope you now have an understanding of how these loops work.
This kind of programming is notoriously difficult to get your head around. Once the penny drops it gets easier.
The problem is our brains are not too good at thinking about two things at the same time.
It’s called spaghetti programming for a reason.
My advice with all programming is to break the program down into small manageable chunks. Make simple little programs of each part and prove them till they work. You can the piece your program back together.
