Reset To G54 Fanuc Parameter 1201
Category : Fanuc Parameters
Reset To G54 Fanuc Parameter, altering this parameter will make the control reset back to G54.
If you find it annoying that your control keeps jumping back to G54 when you press reset change this parameter to a 1.
To change parameters you need to go to the setting screen in MDI.
First of all take a deep breath and prepare yourself.
Now put a 1 in the parameter write box.
How annoying is it when you press reset on your Fanuc control and suddenly it dumps the work offset. You know your in G55 and it jumps back to G54.
I reminds me of my teenage years when girls used to hit the reset button on me. I didn’t default to G54 or anything just got really pissed off.
One particularly ungrateful girl dumped me after I had spent nearly an hour trying to explain to her about the system variables on a Fanuc Control. I even offered to lend her the Fanuc Manual.
This parameter is quite difficult to find. Now I know I often go on about me not being very bright but it really is true. I often say to customers I’m the one who just reads all the boring shit in the manuals that you can’t be bothered with and that’s really all I do.
It’s actually true although,0000000000000000000000000000000000000000 I do like to think that I have a good way of explaining things in “layman’s terms” as they call it, profanities included.
(sorry the cat sat on my keyboard again)
This is my cat she is called Hagnes, that’s not a typo. Her name was Agnes but as she is an upper class cat I added an H because posh people add H to a lot of words.
They often say words wrong like they say “help” when they mean “elp” it’s no wonder we don’t know what the fuck they are on about.
This is all really hypocritical from the guy who fuckin hates it when people put gratuitous crap on Linkedin that belongs on TikTok or Facebook. I mean do I really care if you had two eggs for your fuckin breakfast or one.
Anyway she did stand on my fuckin keyboard.
The parameter, the parameter oh yes…..
The reason not many people adjust this parameter is because it’s kind of hidden. That means it’s down to people like me who sit reading Fanuc Parameter Manuals when all other adult men are playing Candy Crush or Cyberpunk 2077.
This Is It Folks (1201 bit 7)
This is the Explanation.
Extract from an ancient Fanuc manual dating back to biblical times.
Parameter 1201 bit 6
Always read the small print.
Must admit I didn’t read the little note above until I changed this parameter for one of my victims the other day. It didn’t work. Just altered the one below and Bingo.
This Parameter will Need Changing TooReset To G54 Fanuc Parameter
Phew I need a lie down after that.
This parameter is complicated because it’s all about G code groups. Every G code is in a group it is not something you need to worry too much about until you get on to more advanced Macro Programming.
If you think of it as G codes that you couldn’t have in the same block like G0 G1 G2 and G3.
You can only have one or the other. I mean you couldn’t G0 and G1 together that would be stupid telling the machine to rapid and feed at the same time.
Well…… these are in the same group it’s group 1 actually.
This parameter will reset whatever G code is active in group 14.
Group 14 just happens to be G54 G55 G56 G57 G58 and G59 (your work offsets).
As they are all in the same group (14) only one can be active.
So all it means is when you press reset if the machine was in G55 G56 G57 G58 or G59 it would always default back to G54
Now you know how to reset to G54 by altering a Parameter.
So 1 means don’t reset to G54 and 0 means reset to G54
Here is More Total Confusion
Parameter are listed like this
Parameter bits
I’ve written the bit number below because it can be a bit confusing. There are 8 bits beginning with bit zero. The first one is not bit 1 it’s actually bit zero.
So what’s confusing?
Well for one thing they work from right to left.
The other thing is they start at number zero not number one.
It’s all because they are binary numbers without these you and I would still be winding handles and drinking out of our hands and living in caves.
I’m not gonna go there by the way.
Just One Thing
Do yourself a favour take a picture of the screen before you change your parameter.
Make a screen shot if you can.
If you ain’t got a camera then you must have a piece of paper so write it down.
(Oh and get a fuckin camera, you dinosaur, they are very useful you can take pictures of your arse and send them to your mates)
Even better back everything up, on our machine that is.
Reset #100-#149 Fanuc Parameters 6001
If you write macro program you will probably know that 500 series variables stay in the machine even when you switch it off.
Unfortunately the 100 series variables don’t stay around. This parameter when changed means these little blighters will retain their values even if you turn off the machine.
G91 Non modal Haas Setting 29
Now I don’t want to appear sexist here but sometimes my wife will be awake at night worrying about whether or not she left a gas ring turned on.
Now me I worry about different things I mean how can you compare a gas explosion to a collision on a CNC Machine.
(I really should clean that cooker)
Anyway my point is if you worry about G91 and if you left one active in a program and it causes a collision.
Help is at hand. Now this maybe another piece of useless shit and you might wish you had stayed on Facebook, reading your mates post, ruminating on the benefits of vegan cheese and how you can’t tell the difference. (I have tried and it’s really nice once you get the thought of eating semtex out of your brain).
Don’t set me off about vegans. Just answer one question, if they don’t like meat why do they have to keep banging on “I’ve just eaten this burger and you would think it was real beef”
Anyway if you change setting 29
G91 becomes non modal read this article if you need to know more
Anyway what it means is that if you wrote some code like this
G90 G0 X0 Y0
G81 G98 Z-20. R1. F100.
G91 X50
X10.
X20.
X30.
G90 X100.
You would have to write it like this
G90 G0 X0 Y0
G91 X50
G91 X10.
G91 X20.
G91 X30.
X100. (This would go back to G90 automatically)
“That’s daft” I hear you say.
Well not really because it means that if you ever forget to switch back to absolute (G90) it doesn’t matter because it never got swapped in the first place.
Every time you want G91 you need to write it in that block of code.
 Best Website with Crack Program:
Jumping Sections of Programme Using M99 and Block Skip
Click for M99
Contact: 07834 858 407
Using Macro System Variables
Category : Macro New Stuff
Macro System Variables, I often get random emails from people asking me all sorts of questions.
I got one only the other day it began “Hi David, your articles are shit”
I don’t answer every email I get, but I try to answer when I think there is an appropriate response or I feel I can help.
Anyway someone called Neil from America (I think) asked me if I would create a tool setting macro. This involves using Macro System Variables
There is a really annoying thing on a Fanuc control (well actually there are quite a few). This one really pisses me off because I find myself making excuses for the control. I mean like I designed the fuckin thing.
For one, I am nowhere near clever enough and don’t even work for Fanuc. (I am available Mr. Fanuc, sorry I dissed your control)
To set a tool length it’s a really convoluted procedure. You first zero out the Z on the REL display.
You then bring down a tool and get the control to record the Z position by pressing Z then the soft key INP C.
Here’s a couple of videos showing you how.
Origin Z
Use INP C to Enter Offset
Once the Z has been set you can measure as many tools as you want. Just bring each tool down to the setting block and press Z then  INP C.
Here comes the problem…..
If you turn turn off the machine or, for some reason, you have to reference it again you will lose your REL Z position. You will now have to set it again.
Oh and if you don’t notice you’ll be in deep shit. (Your tool length will be wrong!!!)
There are ways around this by using a work offset, but to be honest it’s all a pain in the fuckin arse.
Oh and one other thing. Make sure you write the offset to the correct tool because you can write it to any tool.
Warning
Check the Z zero position each time before setting tools.
A good guide is to slap a good old steel rule or a tape measure against the tool for a rough check.
Macro System Variables to the Rescue
For years I have used a work around on Fanuc Controls. First of all you need to establish where your setting block is. In my case it’s a table probe.
Oh and you need macro (it is an option so if you don’t have it look away now.
To do this you need to note down your machine position in Z when you touch your block or setting probe.
This will later be stored in a variable to be used to calculate the tool length.
Try to set your block in a known position so that each time the Z figure is the same. You may even be able to fix it to the machines table. Don’t weld it, the boss won’t like it.
Read on to see how this variable can be written to automatically with a calibration programme.
The Programme…  OK Let’s Do This
  1. Bring the spindle nose down to touch your setting block. this is the value you will write into #102 (Mine says -500.877)
  2. Call your tool to be measured into the spindle in MDI (T06 M06;)
  3. Bring the tool down to the setting probe.
  4. Run the programme below.
O9001(Tool Measurement Macro)
1.  #100=#4120 (Grab Tool Number);
This will cause the machine to store the current tool number in #100
2. #101=#5023 (Store Machine Z Position);
This will cause the machine to store the current Z position in #101
3. #102=-500.877 (Setting Block Z);
This is the figure you recorded from the position of the setting block.
4. #150=#102-#101 (Calculate Tool Length);
Now we can calculate the tool length by taking the known position from the current position.
This will give us a minus figure, we will reverse this in the code below.
5. #150=-#150 (Reverse Z Figure);
6. G90 G10 L10 P#100 R#150
This puts the tool length into the correct offset.
7. G28 G91 Z0 (Return Z To Zero Return);
8. G90;
M30;
More Explanation (Macro System Variables)
System variables know shit.
What I mean by this is that system variables contain information about the system. Some are read only and some you can write to, like the tool offsets for instance.
You can ask the system loads of stuff like.
  • What speed do you have stored?
  • What’s the tool in the spindle?
  • What position are you in?
  • What modal G codes do you have.
  • How old is my auntie Joan?
  • Do I have a fat arse?
These are all stored in special Macro System Variables except the last two.
You can read them and sometimes you can write to them. It’s not like that bloke at work who thinks he knows every fuckin thing. Sometimes he’ll listen, but most of the time he has to tell you.
No, no macro system variables follow special rules.
Anyway (The Explanation)
8. G90;
M99;
The first line 1. looks into system variable #4120 which contains the number of the current tool in the spindle.
You ask what this is and then put it in #100. Obviously you can’t write to this variable.
The next line 2. asks where the machine is in Z (Machine Position) #5023. Again you can’t write to this but you can store it in #101.
Line 3. stores the value that you measured early in #102. This is where your measuring block is from zero return.
In line 4. you take these values away from one another to give you the tool length
This ends up as a minus figure so we need to reverse it. We do this on line 5.
Line 6. is a standard G10 because we have L10 this means it writes to tool lengths. P is the tool number and R is the tool length.
I always stick a G90 at the front of this G10 in case some twat  leaves the machine in G91 in which case it will add to the existing tool length. (Oh dear total fuckin dog shit mayhem)
So You Want To Use Macro Like An Adult?
Lots of programmers use macro in a very complex and confusing way but I think that is the way they want it so you think “wow he must be a clever bastard.
In my opinion a good macro should have a really simple interface.
I’ll show you mine.
M200
Yep that’s all it is
M200 is aliased to my programme O9001 meaning if you run M200 it goes into my programme 9001 and returns.
Don’t forget you can run M200 in MDI too.
Read this article if you don’t know how to alias a macro to an M code or a G code.
More Macro System Variables
Now what we could also do is when we bring the spindle nose down to set the original Z figure, we could make the machine store this in #500 instead of my #102
500 series variables stay in the control even when it’s switched off. These variables are the cockroaches of macro programming (they survive anything).
In the event of a nuclear war the survivors would be as follows:
  • 500 system variables
  • Some cockroaches.
  • Ozzy Osbourne.
  • Keith Richards.
  • My mother in law.
The code for this is really simple. Just one line in fact,
All you need do is bring your spindle down to the setting block. Then run M300, which I have aliased to programme 9002
Or if you like just run programme 9002
O9002 (Calibrate Table Block);
#500=#5023 (Z Machine Position);
M30;
Word Of Caution
Don’t use M99 at the end of your Macro unless you are calling it with an M Code Alias. Otherwise it will be stuck in a never ending loop.
So Now It’s Simple
Bring the spindle down to setting block and run M300.
This sets #500. If the block is in the same place then this is not needed.
Call the tool you want to measure to the spindle in MDI otherwise it won’t be registered in #4120
T20 M06;
Bring the tool down to the block and run M200.
Or simply type M200 into MDI and run it.
This will then store the tool length in the correct offset.
  • CNC programmer training.
