Offset Keylock Fanuc Parameter 3291
Offset Keylock Fanuc Parameter, before you change this you will need to go to the setting screen in MDI.
From here you can allow yourself to alter parameters.
Today we are going to change the parameter that stops operators from altering wear offsets.
Apprentices should be inquisitive it’s normal. We want them to experiment and learn by making mistakes.
Mmmm sounds great but and there is a big but. By a big but I don’t mean a big arse I mean but with one t.
I once trained an apprentice on a Haas VF1. He picked it all up really fast. When I revisited he was really excited to show me how  he’d learned to alter parameters all over the place.
It was real scary stuff he thought it was fuckin space invaders or some computer game.
Game Over
Game over on a CNC machine means you just buried a tool in a part and caused £5000 worth of damaged or somebody just died for real.
The key switch is now needed.
Parameter 3291 will stop operators from changing the tool wear offsets. It requires use of a physical key to unlock them.
So you just pull the key out and depending how the machine is setup It’s like you just made him wear boxing gloves.
So in Parameter 3291 you can set bit 0# (WPT) to a 0 and you will need to use the key to edit offsets.
By the way it wouldn’t have stopped my rogue apprentice I think he’s the MD now.
Bits n Bobs
Other Parameters Of Interest
1300 Stops over travel alarm
3101 Clear Screen
3102 Unlock Programs
3203 Clear MDI Screen
That’s it away you go, Offset Keylock Fanuc Parameter
Retain Geometry Fanuc Parameter 5003
Retain Geometry Fanuc Parameter 5003, to change this parameters first you need to go to the setting screen in MDI.
Today we are going to change the parameter that stops your tool offset from being dropped when you press reset.
Parameter 5003 will stop that annoying thing where you activate a tool offset and then press reset and it clears.
If you have a Mazak machine you will know that if you index to tool 6 the offset will be instantly activated. This means if you are on a CNC Lathe you can just move the tool to a 50mm diameter and turn away. Providing the tool has been measured the size will be correct.
You are probably used to the tool not being active if you use a Fanuc control but help is at hand.
With this parameter 5003 set to 1
You input T0101 in MDI and that activates tool number one’s offset. Your position display is now correct (allowing for tool geometry).
If you now look at the ABSOLUTE position display and press reset it will not change. If it changes then the machine is more than likely dropping the tool geometry.
#6  (LVK) Set to 1 not cleared on reset
#7 (TGC) Set to 1 not cleared on reset
Bits n Bobs
3101 Clear Screen
Power Up Fanuc Parameter 3402
Power Up Fanuc Parameter 3402. To change parameters you need to go to the setting screen in MDI. Now put a 1 in the parameter write box.
Today we are going to change the parameter that sets all the modal G codes when you first turn on your machine. This is often known as the wake up state.
Power Up Fanuc Parameter How it works?
When you switch on your machine certain G codes will be active. But what G codes are active?
Well….  they are whatever you set in this parameter.
Imagine you just typed in X50. Y50. in MDI and pressed cycle start. Would it rapid, feed or try and go around in an arc?
In parameter 3402 the different bits set the G codes that are active when you first turn on your machine.
#0 G01 (Set to zero you wake up in G00 set to 1 you wake up in G01)
#1 G18 (Set to zero you wake up in G17 set to 1 you wake up in G18)
Things like the machine waking up in incremental can be a potential disaster.
Bits n Bobs
3101 Clear Screen
Do yourself a favour take a picture of the screen before you change a parameter. If you ain’t got a camera then you must have a piece of paper.
Even better back everything up on a regular basis.
Subroutines Fanuc Parameter 6005
Subroutines Fanuc Parameter 6005, to change this parameter you need to go to the setting screen in MDI.
Today we are going to change the parameter that allows us to use local subroutines on your Fanuc control.
To call a subroutine on your fanuc control. You first need to make sure that Bit 0 (SQC) of parameter 06005 is set to 1
(See yellow square.)
Oh and before you get over excited this option is only on newer controls.
Doing it on a Siemens control
Local Subs Fanuc Parameter 6005
A local subroutine is where your sub-programs are included in your main program.
Programmers like to do this because it makes programs very easy to manage. Heidenhain and Siemens controls all have this facility.
Early Heidenhain controls only had this internal way of using sub-programs.
External Verses Internal
External sub-programs are separate so effectively you call one program from another.
The good thing about a separate sub-program is that you can call it from any of your main programs.
This means you could use it to send your turret on your CNC Lathe to a convenient position for tool changing. When you want a safe tool change position in any of your programs you can call this up and know it works.
Siemens controls are very versatile when it comes to sub-programs and they are really easy to manage.
Bits n Bobs
3101 Clear Screen
M Code Alias Fanuc Parameter 6080
M Code Alias Fanuc Parameter, to change this parameter you need to go to the setting screen in MDI.
Today children we are going to change the parameter that allows us to alias an M code to a 9000 series program.
Bits n Bobs
Alias What the fuck is an Alias?
Well to use an alias you have to know a bit about Macro programming
Now if you don’t it’s probably going to be best if you go and play with your Xbox.
But if you do know about macro (and you don’t need to know much).
It means you can write a program to do something and use your own special M code to call it.
So for example if you were to put 384 in parameter 6080.
If you program M384 you would be directed to program 9020.
Parameter 6080 is thecode for program 9020
Parameter 6081 is thecode for program 9021
Parameter 6082 is the code for program 9022
Parameter 6083 is the M code for program 9023
Parameter 6084 is the M code for program 9024
Parameter 6085 is the M code for program 9025
Parameter 6086 is the M code for program 9026
Parameter 6087 is the M code for program 9027
Parameter 6088 is thecode for program 9028
Parameter 6089 is the M code for program 9029
Now program 9020 could look like this.
09020 (M384 Macro)
M9 (Turn off Coolant)
M5 (Stop Spindle)
G40 (Cancel Cutter Compensation)
G80 (Cancel Canned Cycle)
G90 (Absolute)
G0 G53 X0 (Return X To Tool change Position)
G53 Z0 (Return Z To Tool Change Position)
(Any Old Shit You Want to Do)
So when you program M384 in MDI or from a program it jumps into program 9020 and does all that lot.
There is just no end to the stuff you can do with this. I’m not telling you anymore cos I need the work and probably couldn’t handle the competition.
3101 Clear Screen
Oh Yea By The Way
If you want to learn macro programming look no further.
