Subroutines Fanuc Parameter 6005
Subroutines Fanuc Parameter 6005, to change this parameter you need to go to the setting screen in MDI.
Today we are going to change the parameter that allows us to use local subroutines on your Fanuc control.
To call a subroutine on your fanuc control. You first need to make sure that Bit 0 (SQC) of parameter 06005 is set to 1
(See yellow square.)
Oh and before you get over excited this option is only on newer controls.
Doing it on a Siemens control
Local Subs Fanuc Parameter 6005
A local subroutine is where your sub-programs are included in your main program.
Programmers like to do this because it makes programs very easy to manage. Heidenhain and Siemens controls all have this facility.
Early Heidenhain controls only had this internal way of using sub-programs.
External Verses Internal
External sub-programs are separate so effectively you call one program from another.
The good thing about a separate sub-program is that you can call it from any of your main programs.
This means you could use it to send your turret on your CNC Lathe to a convenient position for tool changing. When you want a safe tool change position in any of your programs you can call this up and know it works.
Siemens controls are very versatile when it comes to sub-programs and they are really easy to manage.
Bits n Bobs
1300 Stops over travel alarm
3101 Clear Screen
3102 Unlock Programs
3203 Clear MDI Screen
2 Comments
Stefano
January 2, 2023 at 4:25 pm
My Fanuc 16MA don’t have this parameter is there a solution ? it has only 6001-6002-6003-6004 then jump to 6010
    January 11, 2023 at 3:14 pm
    Unfortunately I don’t think you can do it on that control. Try using M98 and Q and see if it jumps to an N number just to see if it works
