Category : Fanuc Turn
So imagine you did this and bent the machine. The boss says “Ok this is a no blame culture”. Then after he fires you and shoves a P60 up your arse he looks for a way to stop this happening again.
mmm corned beef hash for tea
Memory Search
With a Fanuc control the only thing you can search for inĀ MEMORY (AUTO) mode is an N number.
Why you may ask?
Here is the Plan
  • Each tool has an N number that corresponds to it’s T number.
  • You only use N numbers from 1 to 20 for this purpose.
  • N numbers in your turning cycles are in the hundred series N100 to N900
  • If you have to use other N numbers use N1000 to N6000
  • Only restart your programme in MEMORY (AUTO) mode.
  • Search for the tool number you want to start at (T1 will be N1)
  • Off you go.
  1. You could pick the wrong tool.
  2. You could pick the wrong N number like N6000 for example.
  3. You could be blind drunk
In Conclusion
Proof that they love you really.
Create an SOP for programme restartĀ  (Standard Operating Procedure).
This would catalogue exactly how to perform a programme restart within your organisation.
If you are affected by any of the issues raised in this article please contact us.
Oh and let me know what you think. How do you do it? (Programme restart)
