Category : Fanuc Mill Fanuc Turn Haas Mill Haas Turn Mazak Mill Mazak Turn
And by the way neve use the letter O it’s number zero
GO2 GO2 looks almost exactly the same as G02 G03. But your control will blow it’s mind and get real mad with you.
If you want to know how to do this on your Heidenhain control you need to read this article.
Oh and please don’t call it interpolation as it annoys me.
- Linear interpolation is movement in a straight line.
- Circular interpolation in moving in a circle.
- Interpolation is the movement.
Then your CNC controler magically creates your circle. You can programme any arc like this with one exception.
Do you know what it is?
Ok I will tell you later.
Lets go back to school.
Let’s see what the control has to do to work out where the centre of the circle is. It knows its current position and in your G3 line you tell it the end point and the radius you want.
And that’s how the maths works.
Oh Before you Go More on G02 G03
You can do it but you would have to break it into two halves.
Did he say almost?
Well yes almost. You could programme forever and never bother about I and J with G02 G03. So just go off and watch some porn for awhile and I will explain to the real programmers when you can use it.
In the old days I and J was the only way to programme an arc. You would tell the control where the centre of the circle is and the endpoint. This is cumbersome and a bit tricky. That’s why I’m not telling you fully how to use it.
Anyway one really good simple way to use I and J is for a full circle. Oh and it’s bloody easy. That’s once I’ve explained it to you.
Click here for more info on full circle
When I was a boy hundreds of years ago I had a toy called a spirograph. A series of plastic gears. You stuck your pen in a hole in the gear and rotated it around another gear. With a bit of practice you could make some really nice pictures. Kept us happy for hours the crime rate dropped dramatically in my area when these things came out.
In Comes I and J
Now if we use I and J there are four options as above.
- G3 I-20.
- G3 I20.
- G3 J20.
- G3 J-20.
And that’s it.
So these are the four options
So there you have a fantastic way to programme a full circle without having to break it down into two halves.
Why only one figure G3 I-20.
That’s because you are already at the endpoint so there is no need to repeat it.
