Category Archives: Mazak Mill
G82 Drilling Program Example
X55. Y55.
X-55. Y55.
X-55. Y-55.
X55. Y-55.
Here is the CNC code
This is because of the G98.
Haas G82 example
X55. Y55.
X-55. Y55.
X-55. Y-55.
X55. Y-55.
G73 Peck Drilling Program Example
The G73 Cycle instructs it to drill a hole 17.5mm deep (Z-17.5) at a feed of 200mm per minute (F200.)
G73 Drilling Example
Haas G73 example
CNC Program Quiz What’s Wrong?
Category : Mazak Mill
CNC Program
I got a desperate call from a customer asking me what was wrong with the CNC program below as he kept getting alarms.
The machine is a Horizontal Mazak running an (G Code) CNC program. It’s a thread milling CNC program.
I found quite a few errors in the code quite quickly and congratulating myself confidently told him to run the program.
This guy has been my best friend since I was 17 and I couldn’t resist a bit of sarcasm (we call it piss taking here in England).
You have to be careful when you have a go at Garry. Ever since our days together as apprentices at Rolls Royce (circa 1971) whenever I took the piss out of him he would get me back 10 fold.
(It’s no coincidence that Rolls Royce went bust in 1971)
I remember my first time at arc welding nervously trying to master the technique. Garry thought it might be amusing to smash a large mallet into the underside of the metal clad welding both.
I have always been the type of person who jumps and alarms quite easily.
Panic struck I threw the complete welding torch into the air and spontaneously evacuated my bowels. It sparked and flashed around the cabinet, which I had long since vacated, for a good minute before the instructor intervened.
I was the subject of ridicule and derision for the next few days by the whole of the Rolls Royce training school (about 200 teenagers).
For the younger generation, it was in those strange halcyon days when the UK invested in manufacturing. Oh and we had Black Sabbath, Led Zeppelin, Deep Purple and the fuckin Osmonds.
CNC Program
The CNC Program
Anyway enough of that. So yea I thought the program was OK but it alarmed out again.
A sarcastic laugh ensued and comments about “how the Mighty Fall”.
Needless to say I hadn’t found the real error in the code.
I have to call it a school boy error, mind you when I was at school I couldn’t even write my fuckin’ name, let alone error check a complex CNC Program.
I must have demonstrated this a hundred times on a whiteboard. My students took it all in but obviously I didn’t….. So what’s the error?
N30 T16 T72 M06 (5/8″ THREADMILL)
M911
B0
M51
M08
G90 G0 G54 X0 Y35. S3000 M3
G0 Z2.0
G91
G01 Z-20. F1000.
Z0.605
G41 Y-10.548 F263.
G03 X0 Y22.003 Z.907 I0 J11.002
G03 X0 Y0 Z1.814 I0 J-11.455
G03 X0 Y-22.003 Z.907 I0 J-11.002
G40 X0 Y10.548
G90 Z2.
G0 Z50.
Some hints If You Haven’t Got It Yet
When you are in cutter compensation the machine is reading ahead so the alarm my well be a few lines in front of where you are.
There are errors which are more a matter of discipline but won’t cause alarms.
When I check word documents I always put my finger on each word as I read the document.
I find that when you read it your brain is making the same mistake as when you wrote it.
Biggest clue read this on Modal Information.
And by the way never use the letter O it’s number zero
GO2 GO3 looks almost exactly the same as G02 G03. But your control will blow it’s mind and get real mad with you.
It will also do some really weird shit like trying to start a new program. Anyway just don’t do it.
If you want to know how to do this on your Heidenhain control you need to read this article.
Oh and please don’t call it interpolation as it annoys the shit out of me.
  • Linear interpolation is movement in a straight line.
  • Circular interpolation in moving in a circle.
  • Interpolation is movement.
Which one of you bastards said interpolation?
Then your CNC controller magically creates your circle. You can programme any arc like this with one exception.
Do you know what it is?
Ok I will tell you later, it’s OK to not know. (Just means you are little thick).
Lets go back to school.
G02 G03
Let’s see what the control has to do to work out where the centre of the circle is.
It knows its current position and in your G3 line you tell it the end point and the radius you want.
G02 G03
G02 G03
Get yourself a pair of compasses and try it. It’s great fun.
G02 G03
That’s how the maths works.
Fuckin hell I give up.
g02 g03 lathe
G2 G3 No Pot of Gold
Your control will give you an alarm “End Point Not Found” which makes sense because it can’t find one. It’s like the pot of gold at the end of the rainbow.
G02 G03
Oh Before you Go More on G02 G03
You can do it but you would have to break it into two halves. I’m not going to explain anymore because this method is for wimps and peole who can’t be arsed to read my articles.
You know who you are, ordering Chicken Korma in an Indian Restaurant.
Well…… what follows is a full, blow your bollocks off, shit your pants the next day, vindaloo.
Did he say almost?
Well yes almost. You could programme forever and never bother about using I and J with G02 G03. So just go off and watch some porn for awhile and I will explain to the real programmers when you can use it.
In the old days I and J was the only way to programme an arc. You would tell the control where the centre of the circle is and the endpoint. This is cumbersome and a bit tricky. That’s why I’m not telling you about it.
Anyway one really good simple way to use I and J is for a full circle. Oh and it’s bloody easy. That is once I’ve explained it to you.
Click here for more info on full circle
When I was a boy hundreds of years ago I had a toy called a Spiro Graph.
Spirograph those were the days
It consisted of a series of plastic gears. You stuck your pen in a hole in the gear and rotated it around another gear. With a bit of practice you could make some really nice pictures. Kept us happy for hours. The crime rate dropped dramatically in my area when these things came out.
In Comes I and J
G02 G03
So some clever bloke thought fucks this I’ll invent I and J.
If we use I and J there are four options as above.
  • G3 I-20.
  • G3 I20.
  • G3 J20.
  • G3 J-20.
And that’s it.
G02 G03
So these are the four options
G02 G03
So there you have a fantastic way to programme a full circle without having to break it down into two halves or be clever like a newsreader or some twat off mastermind.
Why do you only need the I and not X and Y Dave?
For fucks sake don’t call me Dave my name is David.
I had this really nice guy phone me from Africa the other day. He explained to me that he needed to get his inheritance of 10 million pounds out of England and if I helped him he would give me £20,000. All I had to do was give him all my bank and credit card details. Oh and a small one off payment of £1000.
Of course I agreed, what a bargain. Just as I was about to do this the cheeky bastard called me Dave.
I immediately told him to fuck off. I just hate being called Dave.
I gave him my 96 year old mothers phone number because I thought at least she can benefit from it all. Her name is Mary so he couldn’t shorten that. She only has £1200 in savings so it would be doing her a massive favour.
Explanation
You don’t need to re-state the X  and Y because you are already at the endpoint
Siemens Sinumerik
