Day: March 30, 2026
Star SB-20R Save Programs Fanuc Oi TF
Star SB-20R Save Programs, this machine is a sliding head CNC Lathe it runs two simultaneous programs. This article shows you how to backup your programs to a USB memories stick. It has a Fanuc Oi TF control.
The machine is a Star SB-20R sliding head.
This works for saving to a memory card too, you just need to select it. It also works on most Fanuc controls.
To change this on the settings look at this article
Star SB-20R Save Programs USB
Star SB-20R Save Programs Data Card
First of all make sure you are in the Edit mode
Then make sure you Edit key is in the unlock position. This allows you to edit programs.
If you have two paths, which I do, you will need to select one with this button.
Now Let’s Go Into The Folder
Press the FOLDER button.
Now cursor to your first program you want to copy and press RANGE
As you cursor down, your selected programs will turn blue. If you select too many the control will tell you. All you need to do is move back one program to reduce the selection.
Now press the END button
If you now press COPY your selection will be on the clipboard.
