G01 G00 Basic CNC Programming ( G01 not GO1 )
The letter O is only used for a programme number and a GOTO statement on a Fanuc Control. It’s important not to get it mixed up with the number Zero. So we should really say G zero one ( G01 not GO1 ).
G01 not GO1
When I first learnt to programme, before the First World War, I still remember how daunting the thick yellow Fanuc Manuals were. The Japanese were learning to speak English and we were learning to speak G Code.
Fanuc Manuals
In the Beginning
Okay enough of this bullshit and verbiage let’s talk about G codes.
I often begin my training courses by saying “you only need to know four G codes to programme a CNC, it really is that easy”
G0 G1 G2 G3
What that means is that you can get round any shape with straight lines G1 and circles G2 and G3. Oh and you need to quickly get to the part so use G0 rapid.
Lets Get On with It
G00 or G0 commands a rapid move. That means the axis will be flat out. Maximum foot to the floor, shit off a stick as we say in the Midlands.
Why do I need to know this?
Now lets see.
Move down in Z
G0 Z5.
G01 not GO1
G01 not GO1
G01 not GO1
It’s obvious really.
Just think for a moment:
Looks like this.
G01 not GO1
G01 not GO1
G00 X130. Z-30.
Could be:
G00 X130. ;
Z-30.;
G01 not GO1
Now G01 ( G01 not GO1  )
You do?
G01 X55. Y-200. ;
You would get an angle.
G01 X55. Y-200. ;
The Feed-rate
G01 X55. Y-200. F100. ;
CNC Turning
What About 3 Axis Rapid?
G0 X50. Y20. Z3.
I would definitely advise using it but, and there always is one, just be real careful nothing is in the way. Don’t blame me I’ll just say I never  met you.
Thank you for reading my article ( Basic CNC Programming G01 not GO1 )
2 Comments
Derek
November 11, 2021 at 3:00 am
Excellent article. I’m facing many of these issues as
well..
my site – access35바카라사이트
SUPERSLOT
March 9, 2022 at 1:45 pm
Fantastic article post.Much thanks again.
https://superslot888.net/
