Parameter 3109 Display W and G
Category : Fanuc Parameters
People who know me know just how boring I am. Today I’m going to confirm this by getting very excited about this parameter.
Parameter 3109 bit 1 (#1) DWT will make the display of wear offsets loose that confusing W and G.
Stay here I’ll explain more.
Parameter 3109, to change this parameters first you need to go to the setting screen in MDI.
Today we are going to change the parameter that stops the offset page displaying G and W.
Bit 1 (#1) DWT make this a 1 to stop this being displayed.
So when you change this parameter you won’t see a W beside the offset number in the wear screen. You also won’t see the G beside the tool number in the geometry screen.
I know for a fact when training people that this really confuses them. Especially the the G on the geometry screen.
This is it before with the W
This is it with the parameter change good old fashioned numbers.
As in the book
Bits n Bobs
Other Parameters Of Interest
6050-6059Â Allows you to Call a 9000 series Program with a G Code
Do yourself a favour take a picture of the screen before you change a parameter. If you ain’t got a camera then you must have a piece of paper.
