Polar Programming G16 Fanuc
Polar programming is cool.
No use??? Think about it. Polar Programming G16.
Read on….
Oh No Polar Programming G16 is an Option
Polar Programming G16First thing you need to do is program a G16 to say you want to use polar programming.
G16 on its own means your datum is the centre of the pole (X0 Y0)
Once G16 is active then X becomes your radius and Y becomes your angle.
What’s The Time Mr Wolf?
Now see it running.
Note that the distance to the sharp corner is 46.188 The line N1 uses this.
Incremental
Polar Programming G16 Action
Action
What do you think?
G16…..
4 Comments
Rob
March 31, 2022 at 10:26 pm
That’s just so cool, thanks for the tip
Arvind
December 27, 2023 at 5:36 am
Thank for g cod G16 vidios fanuc
