G00 Straight Line Fanuc Parameter 1401
Category : Fanuc Parameters
Unlock Programs Fanuc Parameter, first of all you’ll need to go to the setting screen and change the parameter write box to a 1.
When you program a rapid move on a Fanuc control which ever axis has the shortest path will arrive first. This will give a dogleg type move and may result in a collision.
Changing parameter 1401 Bit 1 will make this into a straight line move.
6050-6059Â Allows you to Call a 9000 series Program with a G Code
