Category : Fanuc Turn
What to do Next?
Anyway I suddenly realized I didn’t have a dog and that the start position of the tool was wrong.
I had the tool just below the external diameter of the thread. If you do this the machine thinks the thread is internal and therefore cuts backwards.
Correct
Incorrect
Put it here and you are in deep shit. The tool will work from this position backwards.
Don’t say I didn’t warn you.
G0 X21. Z3.
G97 S1200 M3
G76 P010060 Q20 R.02
This thread has a core diameter of 16.96 (X16.93) the thread depth is 1.535 (P1535).
Wrong as Below
G0 X19.95 Z3.
Well now’s the time.
This is my puppy his name is Donald he is learning to program a G71 woofing cycle.
G0 X21. Z3.
G97 S1200 M3
2.5 x 1200 = 3000
Strange Behavior
Maybe you had a pitch error.
G0 X21. Z3.
G97 S2400 M3
2.5 x 2400 = 6000
Eat more fish.
If you have a coarse pitch thread in aluminium you probably will end up with a super high feed-rate you can’t even achieve.
This will all depend on the age of your machine but you must always make this calculation just in case your trying to cut a thread at the speed of light.
You know that old book that you use to prop the door open
