Category : Fanuc Turn Haas Turn Mazak Turn
Basic Turning
G97 Speed In RPM
G97 S1500 M3
When drilling a hole you are on the centreline of the machine so you just want plain old simple RPM.
G96
G96 S200 M3
If the tool was positioned at a 100mm diameter it would be as if the tool were able to run around this diameter at a speed 200 meters a minute.
Neeeeeoooooooowwww
Well maybe you still have a Hamster and that’s not a problem.
Anyway I did and his name was Harold Wilson (British Prime Minister at the time).
Harold Had G96
Harold Was a Clever Bastard
If he was running at 200 meters a minute not only would he be fuckin knakered but the wheel would be running at 291 rpm
200 / .6864 = 291
Using a manual machine you have to compromise. At the outside your speed is too fast and when you get to the center you are too slow.
With a machining center our cutter is always revolving at the same speed so the feed can be constant in mm per minute.
Someone out there will be thinking “what happens in G96 when you get to the center of the part”. Well the spindle will be flat out!
Watch the video
When I train people at the CNC Training Centre my emphasis is on understanding not memorizing. I usually start by saying “please don’t remember all the things I am telling you”.
G96 Whoopee It’s amazing
So use G96 for everything.
Except for:
- Drilling.
- Tapping
- Threading (Screw cutting)
- Fanuc control training.
- Fanuc training courses
- CNC lathe training
1 Comment
Mahran
July 1, 2020 at 10:34 amHi,
I have a monforts cnc with 840c sinumerik control system, i have a problem of spindle speed limitation. My cnc is shutting off after speeding the spindle more than 300 rpm, what can be the solution?
