CNC Milling G02 G03
CNC Milling G02 G03
Training Courses Let Me at Em
First in two halves
G0 X0 Y0 S1500 M3
G43 Z3. H01 M8
G1 Z-5. F100.
G41 X20. Y0 D1 F200.    (Apply Cutter Compensation)
G3 X-20. R20.                   (First Half)
X20.                                     (Second Half)
G1 G40 X0 Y0                   (Cancel Cutter Compensation)
G0 G53 Z0
G1 G41 X20. Y0 D1 F200.
G3 X20. Y0  I-20. J0 (Mill Full Circle)
G1 G40 X0 Y0
G3 I-20.         (Mill Full Circle….. Sooo Simple)
G1 G40 X0 Y0
G3 I-20. (Mill Full Circle)
I-20.        (Lets go round again)
G1 G40 X0 Y0
                D1 (Use offset 1)
                I20. (20mm Radius)
No there is no sexual inuendo here it just means you approach the circle using in a circular move. You sort of creep up when it’s not looking.
Know what I mean??
CNC Milling G02 G03
CNC Milling G02 G03
Now look at this.
CNC Milling G02 G03
CNC Milling G02 G03
CNC Milling G02 G03
CNC Milling G02 G03
Simple Full Circle Programme
G3 I-20.
G1 G40 X0 Y0
CNC Milling G02 G03
G3 I-20.    (The one on the left and the one we used)
G3 I20.     (The one on the right)
G3 J20.    (The top one)
G3 J-20.  (The bottom one)
Here They Are In Action
CNC Milling G02 G03
CNC Milling G02 G03
Click for More on G02 and G03
Call David
