Cutter Compensation
Category : Fanuc Mill Haas Mill New Stuff
Cutter compensation explained.
Call 07834 858 407
This is a video explaining cutter compensation in CNC programming.
- Tool cutter comp.
- CNC cutter comp.
- G41 G42 cutter compensation.
- Cutter diameter compensation.
- Cutter radius compensation.
- Heidenhain RL RR.
This means that when you input the data for your cutting tool in your offset table you can use the diameter or the radius of the tool. This depends on your settings.
(Cutter compensation G code)
- G41 cutter compensation left
- G42 cutter compensation right
- G40 G code to cancel cutter compensation
This Video shows you :
- How to program G41.
- How to program G42.
- CNC cutter compensation examples.
- Cutter compensation Heidenhain style.
- Heidenhain RL RR.
We always recommend that you climb mill so you will be using G41 most of the time.
Rules are the same as the tool nose radius compensation on a CNC Lathe.
If you programme a shape and you do not use cutter compensation you will have to work out the size of the shape with your tool radius added.
- What will you do when your cutter wears?
- What if you want to use a different size cutter?
- The cutter may not run true.
- What if the cutter is not exactly size?
The Rules:
- Shape must be continuous and consistent.
- You can’t cut along a line and then go back along it.
- It’s important to allow more than the tool radius when entering tool compensation. The same applies when you come out of tool compensation.
- Internal corner radii and steps must be greater than the tool radius.
Don’t ask
Call 07834 858 407
- Fanuc training.
- Fanuc programming training.
