Category : Haas
Reposition Haas Mid-Program
Piss easy.
Same Shit different Day
Back to Reposition Haas Mid-Program
Here We Go
You will now see the message “Jog Away”on the screen.
Do whatever you want to do.
- Inspect the part.
- Blow the hole out.
- Remove your own appendix without anesthetic.
Now go back into memory mode.
Press Cycle Start.
Then ZÂ axis.
And bang away you go.
The program continues.
1 Comment
cristi
November 2, 2019 at 7:43 pmwhattttttt?????????????? I’ll try that !!!
