X55. Y55.
X-55. Y55.
X-55. Y-55.
X55. Y-55.
The G73 Cycle instructs it to drill a hole 17.5mm deep (Z-17.5) at a feed of 200mm per minute (F200.)Â
This is because of the G98.
G73 Drilling Example
