Cutter Compensation
Category : Fanuc Mill Haas Mill
Cutter compensation explained.
Call 07834 858 407
This is a video explaining cutter compensation in CNC programming.
- Tool cutter comp.
- CNC cutter comp.
- G41 G42 cutter compensation.
- Cutter diameter compensation.
- Cutter radius compensation.
- Heidenhain RL RR.
In the parameters or settings of your control you can set up your system to allow for the radius or the diameter of your cutting tool.
This means that when you input the data for your cutting tool in your offset table you can use the diameter or the radius of the tool. This depends on your settings. My experience is that most people use the diameter but be sure to check if you are on a new machine.
(Cutter compensation G code)
- G41 cutter compensation left
- G42 cutter compensation right
- G40 G code to cancel cutter compensation
This Video shows you :
- How to program G41.
- How to program G42.
- CNC cutter compensation examples.
- Cutter compensation Heidenhain style.
- Heidenhain RL RR.
We always recommend that you climb mill so you will be using G41 most of the time.
Rules are the same as the tool nose radius compensation on a CNC Lathe.
If you programme a shape and you do not use cutter compensation you will have to work out the size of the shape with your tool diameter added. This is simple on a square sided figure or a simple radius. Anything more complex and it’s a nightmare.
- What will you do when your cutter wears?
- What if you want to use a different size cutter?
- The cutter may not run true.
- What if the cutter is not exactly size?
In the old days of paper tape and Corned Beef we as programmers would write several programmes. This was so that we could re-grind the milling cutters in fixed increments. A different programme could be used each time the tool was changed. Sorry I can’t talk about this much longer as I still have the nightmares (mainly about corned beef sandwiches).
The Rules:
- Shape must be continuous and consistent.
- You can’t cut along a line and then go back along it.
- Allow more than the tool radius to enter tool compensation. The same applies when you come out of tool compensation.
- Corner radii and steps must be greater than the tool radius.
Always allow more than the radius because when you adjust it it may be larger than the actual tool you are using. For example if you have a 12mm endmill but you have .2mm in the wear compensation. The machine thinks that the tool is 12.4mm in diameter.
Anyway here is the video and don’t forget to subscribe to my YouTube channel.
Call 07834 858 407
- Fanuc training.
- Fanuc programming training.
