Display 9000 Programs Fanuc Parameter 3202
Category : Fanuc Parameters
Not display 9000 Programs Fanuc Parameter, first of all you’ll need to go to the setting screen and change the parameter write box to a 1.
Programs 9000 to 9999 are used for things like probing, tool-change and all sorts of other important things.
You are allowed to use them but proceed with caution.
Beware and above all back em up ASAP.
These programs will not be displayed when this parameter PSR #6 is a 1
3202 if #6 PSR is 1 then programs 9000 to 9999 can’t be displayed.
As per Manual
Don’t forget to lock the 9000 programs back up and turn off parameter write switch.
Bits n Bobs
Display Programs Fanuc Parameter 3202
You might want to use this yourself if you have a sub program in your machine that you use quite often and you don’t want anyone messing with it.
Other Parameters You may Want to Change
1300 Stops over travel alarm
3101 Clear Screen
3203 Clear MDI Screen
