Fanuc CNC Parameter 14852, Fixed Form Character Length
Fanuc CNC controls include hundreds of parameters that quietly shape how the control behaves. One that often goes unnoticed—but can make a real difference to usability and program readability—is Fanuc CNC Parameter 14852, Bit 4.
This article explains what parameter 14852 bit 4 does, when you might want to change it, and what to watch out for before making any adjustments.
Shibaura Training
What Is Fanuc Parameter 14852 Bit 4?
Parameter 14852, Bit 4 controls the number of characters that can be displayed or entered in each fixed form field on supported Fanuc CNC controls.
When this bit is enabled, the control allows more characters per fixed form, effectively expanding the usable text length within those fields.
In practical terms, this means:
  • Longer text entries are possible
  • Descriptions and identifiers are less likely to be truncated
  • Fixed-form screens become more informative and easier to interpret
The exact behaviour can vary slightly depending on the Fanuc control series and software version, but the purpose of Bit 4 remains the same: increase character capacity per fixed form.
What Are Fixed Forms on a Fanuc Control?
Fixed forms are structured input screens used to quickly create program.
Typical forms:
  • Start of program
  • Call a tool
  • Call a cycle
  • End a program
I means the programmer does not need to memorise loads of G and M codes. The structures is created.
For more details on Fanuc macro variables and fixed forms, check our Fanuc Parameters that cover advanced control functions.
Why Increase the Number of Characters per Fixed Form?
Enabling Parameter 14852 Bit 4 can be particularly useful in the following situations:
1. Improved Program and Process Clarity
Longer character limits allow more information to be added in one keystroke.
2. Better Operator Understanding
Operators can see more meaningful descriptions without abbreviations, reducing the risk of misunderstandings on the shop floor.
How to Set Fanuc Parameter 14852 Bit 4
⚠️ Important: Always back up parameters before making changes. Parameter behaviour can differ between control models.
To change parameters
You need to go to the setting screen in MDI. Now put a 1 in the parameter write box.
Fanuc CNC Parameter 14852 Bit 4
Put a 1 in here.
Compatibility and Control Versions
Parameter 14852 Bit 4 is commonly found on:
  • Fanuc 0i series
  • Fanuc 30i / 31i / 32i series
However:
  • Not all options are enabled on every machine
  • OEMs may lock or modify behaviour
  • Software revisions can affect results
Always consult:
  • The machine tool builder documentation
  • Fanuc parameter manuals for your exact control
Parameter, Risks and Considerations
While enabling this bit is generally safe, keep the following in mind:
  • Some custom screens may be designed around the original character limit
  • Consistency across multiple machines is important in production environments
Summary
Fanuc CNC Parameter 14852 Bit 4 is a small setting with a surprisingly positive impact. By increasing the number of characters allowed in each fixed form, it improves clarity, usability, and allows you to add more code with one quick insert.
