G83 Peck Drilling Program
G83 Peck Drilling Program Example
G83 Peck Drilling Program, G83 is a deep hole peck drilling canned cycle.
Cycle G83 drills holes breaks up the chips as it goes. It fully retracts from the hole after each peck.
X55. Y55.
X-55. Y55.
X-55. Y-55.
X55. Y-55.
Here is the CNC code
The G83 Cycle instructs it to drill a hole 17.5mm deep (Z-17.5) at a feed of 200mm per minute (F200.)Â
The Q2. tells the machine to drill the hole in 2mm steps. After each step it retracts to the surface of the part.
This allows all the chips or powder to come out of the hole after each cut. It also allows the drill to cool.
This is because of the G98.
G83 Drilling Program Example
