Sinumerik Training Sub Programs
Sinumerik Training, with Siemens Sinumerik there are many ways to call a subprogram. Subprograms are a really convenient way to repeat a piece of program.
You could have an incremental program and call it in several places. You could profile the outside of a part with two different tools. One for roughing then one for finishing.
Siemens Training Click Here
The program below calls an external subprogram “THE_SHAPE” twice. The first time with a 20mm Endmill then the second time with a 10mm Endmill.
External means it’s another program somewhere in the directory.
Sinumerik Training
This is the subprogram.
Sinumerik Training
These subprograms need to end with an M17 (Fanuc uses M99). This tells the control to go back where it came from.
Providing the program is in the same folder as your main program then you just need to write in the name to call it.
Siemens Program Training Cool Siemens Stuff
This Article is About TOFFR
TOFFR….  No it’s not some kind of vegan substitute for cheese.
It’s a programming command on a Siemens 828 or 840 Sinumerik Control.
Now everyone who reads this crap knows that I usually start the articles about Siemens Program Training by saying how versatile they are.
Well today I’m not going to. Instead I’m going to show you a picture of the fly I bought from a local pet shop.
Her name is Tinkerbell.
“I want to buy a pet fly” I asked. “We don’t sell them” said the shopkeeper.
“Well there are quite a few in the window” was my reply.
I then forced him to sell me one for £25 (that taught him a lesson, I think he was afraid I’d call in trading standards)
Siemens Programme Training TOFFR
I could talk about Tinkerbell all day, but I’m not going to, Iv’e written this amazing article all about TOFFR it’s the Siemens vegan option.
Let’s imagine you want to machine around the outside of a shape. You want to rough it and leave material on. So what do you do?
Two Programs?
Do you have two programs one bigger shape for roughing and one that is the correct finished shape?
No you use TOFFR
What TOFFR does is modify you tool radius in your offset file.
Firstly you add some to it.
TOFFR=1. (Add 1mm)
Run your program which will leave 1mm on the size.
Then…
TOFFR=0 (Sets it back to it’s original amount)
Run your program again this time the tool is back to it’s correct radius and will therefore finish the part.
Take a look at the code below.
WORKPIECE(,””,,”BOX”,48,0,10,-80,-52,-52,52,52)
G40 G94 G64 G90
T=”CUTTER 12″
M6
D01
G54 G94
G0 X58. Y0 S1500 M3
Z-10.5
M8
TOFFR=1.;Add 1mm to radius
SHAPE:
G1 G41 X48.Y0 F1500.
Y-48.RND=10.
X-48.RND=10.
Y48.RND=10
X48.RND=10.
Y0
G40 X58. Y0
ENDLABEL:
TOFFR=0;Reset Radius
REPEAT SHAPE
G0 Z50
M17
Let me explain what’s going on here.
This line:
Will add 1mm to the active tool radius so you mill around the part leaving 1mm of extra material.
Then this line:
Takes the 1mm back off so when you repeat the section of code with this line.
REPEAT SHAPE
It finishes the shape.
Here is a nice video I made.
Oh and if you want to know about repeating sections of program  and subprograms read this.
Siemens End Point and Radius Arc
Writing Siemens Work Offset From Your Program
Siemens Work Offset
On a Fanuc control it is quite common to use G10 to write your work offsets (G54 to G59) from your program. It has many advantages the main one being that no-one gets to mess with your precious work offset once its set.
If some prick comes along and changes it, you don’t have to give a flying monkey shit. Your Siemens Work Offset is safely locked away in your CNC Program.
Oh and you get to do shit like this
Well if you ever lie awake at night thinking “how is that done on a Siemens control” I’m going to give you the answer. I often had these thoughts so you are not alone.
But then one day, not long back, someone asked me outright “How’s it done” once I got over the initial embarrassment of being asked such a direct question I told em.
Well first let’s say there is no such thing as G10 on a Siemens control.
You use this $P_UIFR[1] to write your Siemens Work Offset. The 1 being G54 and 2 G55 you can take this right up to G599.
Beware you are in the adult section now, messing with system variables.
Let me say “I fuckin love Siemens controls” there you go I’ve said it.
But, and a massive but it is, you get the syntax wrong on this and all hell will break loose. Not only will your CNC Machine explode in your face but when you get home your partner will be shagging the window cleaner in the remains of your burnt down house. So beware before you press that button to write your Siemens Work Offset.
You need loads of commas just put em everywhere and you wont go wrong.
This is how it looks:
$P_UIFR[1]=CTRANS(X,100.,Y,200.,Z,300.)
This will set X100. Y100. and Z300.
Great I Can Read and Write
While we are on the subject, you can also read the work offset figures back into R values. You can then keep these and do what you want with them. Maybe sell them to a friend for profit, the choice is yours.
Siemens Work Offset
The 1 just after the square bracket is for G54 (2 would be G55) then give the axis in our case X Y and then Z
R1=$P_UIFR[1,X,TR]
R2=$P_UIFR[1,Y,TR]
R3=$P_UIFR[1,Z,TR]
The video below shows R1 R2 and R3 set to zero, after reading the program it extracts the offset figures G54 X-100. Y-200. and Z-300. and puts em in R1 R2 and R3 variables.
So there you have it setting you Siemens Work Offset.
Easy isn’t it.
You’re a big boy now playing with system variables but just remember “with great power comes great responsibility”
Save Offsets Siemens 828
Save Offsets Siemens 828, I often see my job as a trainer as the bloke who works out what those odd buttons do. You know, the one you see every day but never dared press it because it might cause your machine to implode and completely destroy itself.
As you know I offer on-site training on all types of controls.
Well I was messing with a customers machine today and found another, button that is.
This is the chappie his name is Archive but he does other things other than what it says on his tin so to speak.
If you dare to press him you have the luxury of being able to save all your offset and tools related to your program and you will be blessed with special powers, a bit like Spiderman but without all those sticky bits of thread.
“How cool is that”
What you Do to Save Offsets Siemens 828
First of all you will need to be in Program Manager.
You should then be able to see this screen.
Now press the button.
You will now have the option to press
So go ahead press it.
From the dropdown boxes you can chose what you want to save.
Press OK and everything will be saved in a file which has the same name as your program flowed by TMZ. Not sure what that means but it contains all your shit.
So that’s good (Save Offsets Siemens 828)  isn’t it?
It has the extension INI.
My program was FACEMILL so it added FAEMILL_TMZ.INI
So now it’s easy. When you want to recall this information just open the file (much like you open a program) and there it is.
Just click OK and your data is all reloaded.
Save this file with your program and everything you need is there. Don’t you just love that??
