Edgecam Training (Leicestershire UK)
Edgecam Training Call David: 07834 858 407
This two day course teaches you to program from a basic part in Edgecam right through to machining on a real machine.
Learn to create a program from lines or a solid model then post out the code you can then run it on a real CNC Lathe or Milling machine.
This course is designed to get you using Edgecam in the real manufacturing world.
The course is at our training centre in Barwell, Leicestershire, England.
Apply Here
Apply Edgecam MillingApply Edgecam Turninig
For more details or for on-site CNC Machine training
Don’t waste your money.
Your software wasn’t cheap so now is the time to start using it.
If you are one of those people who came from a manual machine to a CNC Machine then you will remember how strange it all seemed. Something supposedly quicker seemed to take much longer.
Did you ever feel like just going back to the old manual machine cos you thought you could do it quicker?
Edgecam Training Classes
Manual Vertical Milling Machine
Maybe you actually did. Anyway it’s a bit like that when you start using a system like Edgecam. It can be very frustrating.
At the CNC Training Centre we can help you make that transition. We call it “Wasting time to save time”. It means you have to spend some time not actually making anything or working.
You just learn.
Using Edgecam is definitely a much faster way to program and the code should be exactly as you want it.
It is just like a manual machine versus a CNC machine the more complex the part, the more time you save. I guarantee you will never look back. But first you have to get over the pain threshold.
Programming Skills a Useless Waste of Time!
If you are already a good CNC programmer your skills are not wasted. The skills will be used in a different way.
Oh, except it just got a whole lot easier.
For example writing your own post processor for Edgecam will be an absolute piece of piss.
At the CNC Training Centre our Edgecam Training Classes take you right through from design to actual machining. The Edgecam Training Classes give you the confidence to use your software.
Often a few tweaks to your Post Processor can make a massive difference to how your programs look and run.
Don’t Know what A Post Processor is?
Oh dear you are in a bad way. Just joking.
Imagine you programmed your part in Edgecam OK. Now you want some CNC Code.
Well the post processor is the little machine that converts the Edgecam bit into CNC Code. You can have as many Post Processors as you want and depending on which one you pick you will get different code.
Any Machine or Control You Want
Fanuc
heidenhain
Siemens
So once you have a Post processor for your machine and providing that machine is suitable for the part you want to make……
Away you go you can create a CNC program for it.
Wow this is great.
Edgecam Training Classes it gets Better………
Practical Classes
In these classes you can go through the whole process.
From producing a solid model…..
Right through to proving the part on a virtual CNC Machine.
Associativity What’s That All About?
As part of the training we can teach you all about associativity and exciting ways that you can make use of it. Such as moving clamps on fixtures before you actually hit them!!
So if you need help with Edgecam or Part Modler look no further.
co*****@***************re.com
