Apply Now
See all The Courses
Duration: 2 days.
Date: Click for Dates
Times: Start 9.30am Finish 4.00pm
£720 inclusive for the two days
Apply Now
Call David on 07834 858 407
Most ISO type controls that have Macro use a very similar system.
This course covers Lathes and Machining Centres all in one course.
What can you Do With Macros?
- Create your own G codes to make up your own cycles.
- Control programs externally.
- Simplify everyday programming tasks.
- Create one simple program to make families of parts.
- Create your own interface for repeat tasks.
- Write your own probing programs.
- Completely baffle other programmers.
Practical
This course uses practical examples of macro programs all demonstrated on real machines.
So you get to see how it really works.
Once you have grasped the concept of parametric programming you will find Heidenhain Q parameter programming easy to figure out.
What you Need
You need to be an experienced CNC Programmer.
This is not a beginners course.
If you have a good basic understanding of CNC Programming and you feel yo want to progress to using parametric programming then this course is for you.
Haas, Fanuc or similar controls (ISO Mazak).
Make sure you have the Macro option on your control, its a real disappointment when you get all excited about this only to find you don’t have the option. Remember if you have a touch probe you will almost definitely have Macro installed on your machine.
What Use Will it Be?
Apply Now
Write your own canned cycle
Yes you always dreamed of having your own personal G code, you can’t call it like Bill’s G code or something but you may have G271 or something which is personal to you.
Make A Set of Similar Parts
Imagine you had a bunch of parts that were similar, maybe the same holes but in different positions or a similar shape maybe.
You could write a parametric (Macro) program that would be completely adjustable and would make them all instead of having to keep writing similar programs.
You can build these programs and add to them as you get better and better and your ideas flood in.
I always say to students to start simple and build on your experience. Just using Macro in it’s simplest form will inspire you to go on to do greater things.
Interrogate Your CNC Machine
- Spindle Speed
- Position
- Datum
- Tool Length
- What tool is in the spindle
- Put the machine into an alarm state when things go wrong like wrong data is input
- And loads more
Do Calculations
- Simple trigonometry
- Calculate feeds and speeds
- Simple maths
- Input formula and get answers
What Skills Will I Learn
- Basic use of variables
- Creating simple Macro programs
- How system variables work
- How to write probing Macros
- Creating your own G Codes
- Create alarms to make sure your Macro users behave
- Practical use of Macro
- Creative use of Macro
- and more, loads more
Apply Now
See all The Courses
Fanuc Training Onsite
Duration: 2 days.
Siemens Sinumerik 840D 828 on and offsite training
