Basic Turning
Basic Turning
G96 Hamsters Large wheel Small wheel
G97 Speed In RPM
G97 S1500 M3
When drilling  a hole you are on the centreline of the machine so you just want plain old simple RPM.
G96
G96 S200 M3
Basic Turning
If the tool was positioned  at a 100mm diameter it would be as if the tool were able to run around this diameter at  a speed 200 meters a minute.
Basic Turning
Neeeeeoooooooowwww
G96 G97 hamster on a Wheel
Anyway I did and his name was Harold Wilson (British Prime Minister at the time).
Basic Turning
G96 G97 all about hamsters
Harold Had G96
Harold Was a Clever Bastard
200 / .6864 = 291
Manual Lathe
cnc turning basics
G50 Warning
Watch the video
Basic Turning
G96 and G97
G96 Whoopee It’s amazing
So use G96 for everything.
Except for:
  • Drilling.
  • Tapping
  • Threading (Screw cutting)
  • Cutting the Lawn
Cutter Compensation
Cutter compensation explained.
This is a video explaining cutter compensation in CNC programming.
  •  Tool cutter comp.
  •  CNC cutter comp.
  •  G41 G42 cutter compensation.
  •  Cutter diameter compensation.
  •  Cutter radius compensation.
  •  Heidenhain RL RR.
Cutter Compensation
This means that when you input the data for your cutting tool in your offset table you can use the diameter or the radius of the tool.  This depends on your settings.
Cutter Compensation
(Cutter compensation G code)
  •  G41 cutter compensation left
  •  G42 cutter compensation right
  •  G40 G code to cancel cutter compensation
This Video shows you :
  • How to program G41.
  • How to program G42.
  • CNC cutter compensation examples.
  • Cutter compensation Heidenhain style.
  • Heidenhain RL RR.
We always recommend that you climb mill so you will be using G41 most of the time.
Cutter Compensation
Cutter Compensation
Cutter Compensation
Cutter Compensation
Rules are the same as the tool nose radius compensation on a CNC Lathe.
If you programme a shape and you do not use cutter compensation you will have to work out the size of the shape with your tool radius added.
  • What will you do when your cutter wears?
  • What if you want to use a different size cutter?
  • The cutter may not run true.
  • What if the cutter is not exactly size?
Cutter Compensation
The Rules:
  • Shape must be continuous and consistent.
  • You can’t cut along a line and then go back along it.
  • It’s important to allow more than the tool radius when entering tool compensation. The same applies when you come out of tool compensation.
  • Internal corner radii and steps must be greater than the tool radius.
Don’t ask
Cutter Compensation
Cutter Compensation
Call 07834 858 407
Polar Programming G16 Fanuc
Polar programming is cool.
No use??? Think about it. Polar Programming G16.
Read on….
Oh No Polar Programming G16 is an Option
Polar Programming G16First thing you need to do is program a G16 to say you want to use polar programming.
G16 on its own means your datum is the centre of the pole (X0 Y0)
Once G16 is active then X becomes your radius and Y becomes your angle.
What’s The Time Mr Wolf?
Now see it running.
Note that the distance to the sharp corner is 46.188 The line N1 uses this.
Incremental
Polar Programming G16 Action
Action
What do you think?
G16…..
Copy Paste Fanuc CNC Control
On or Offsite CNC Training
Tel: David 07834 858 407
Copy Paste Fanuc CNC Control, here is a video that shows you how to copy and paste on a Fanuc control.
Call 07834 858 407
Copy Paste Fanuc CNC Control, in the video I am using the Fanuc 18i on a big vertical lathe but most Fanuc controls are the same or very similar.
