Taking a Screen Shot Fanuc Control
To take a Screen Shot Fanuc, you will need to have either a data card installed or a USB
Screen Shot Fanuc
MDI
In MDI I/O channel needs to be set (4) data card or (17) memory stick
Screen Shot Fanuc
Stick the Card in (or the stick)
Press and hold the shift key for about 10 seconds. You will see the clock stop. That’s how you know it worked. Time will stand still at this point and all the people around you will appear static.
Try not to panic, the world didn’t end. Your control just needs to ponder a while and think about what you just did.
Stop The Clock
Once it’s done your clock wil start again (phew).
Screen Shot Fanuc
Then press CARDScreen Shot Fanuc
Screen will show what is on the data card
Screen Shot Fanuc
The BMP files are your screen shots. You can then view them on your laptop or PC.
Now I know you are saying “what is the fuckin is the use of that”
Well It’s just so that I can show off my knowledge.
Parameter
If this does  not work then you may need to alter parameter 3301 bit zero and bit 7 need to be 1
Should look like this to make it work.
Screen Shot Fanuc
A good use is when you are changing parameters. There’s nothing worse than changing a parameter and trashing a £100,000 machine. Help is at hand, luckily you did a screen shot before you changed the parameter and you can view it and change it back.
With this parameter it wont work because you need to switch it on!!!
Good luck with the massive dent in the guarding and the bent tool. No screen shot will fix that.
Screen capture Fanuc, thanks for reading.
Ten Things You Might Not Know About The Fanuc Sub Program
Sub Program Fanuc
Here are ten things you might not know about Fanuc sub programs,
Fanuc CNC controls are the most common controls in the world so it might be useful to have a good understanding of how sub programs are called and used.
(1) You Can Call a Sub Program By Name.
Yes you heard it here the program can be called by it’s name or it’s number. When calling by name don’t use the P.
Just put the name of the program in these things <> with an M98 and your away.
M98<ALBERT>
The only problem with this is that the syntax needs to be spot on so if you have got complicated names for your your sub routines then you might be in the shit.
I always call mine names like ALBERT that are easy to remember.
(2) You can use internal sub routines on a Fanuc Control.
Some people call these local sub programs. It just means it’s tagged on the end of your program which makes them nice n easy to look after. A bit like a pet Goldfish or a pet fly.
I bought mine from the local pet store. I asked the assistant if he sold pet flies and he said no. I said “well there are loads in the window”.
Anyway he sold me one (£15) his name is Paul
This is not him this is Steve.
Internal Sub-Routines
By typing M98 Q500 your control will look for N500 within your current program. This is great because you can add the sub programs to the end of your main program. Don’t forget to leave big gaps so you can clearly see where and what they are. Oh and mind your P’s and Q’s.
M98 P500 (Call O500 externally)
M98Q500 (Call N500 in main program.
Oh and read this too.
Sub Program
Just one other thing. Watch your n numbers it’s easy to get them mixed up. Try and use a convention.
Fanuc Editing Copy and Paste
Fanuc Editing Oi Model D. This does vary on the age of your control this article is for a newer control (Fanuc Oi Model D).
Read this article if you want to see Fanuc Editing 18i (older control) or this one for older Oi control  copy and paste.
Now I’ll warn you that it’s not a simple process but if you get into the habit of using it you’ll never leave home without it.
I am definitely not going to rant on and on about why all these simple procedures were not introduced years and years ago. Why has the editing on CNC controls generally been so shit over the years?
I am also not going to rant and and whinge about how fuckin complicated it all is.
I mean bloody hell all I want is to take this shit here and join it to the end of this shit here.
I’m not asking  for an “X Factor Audition Here” (Simon if you are reading this my contact details are above) I only write this crap to try and make some money, my really passion is singing and exotic dancing in my underwear. I really want this Simon, just one chance is all I need.
