Oh and It Gets Worse.
And not to mention all that boring maths that you will have to do. You remember that teacher with the beard that kept banging on about ratios and differentiation? Well, maybe you should have paid more attention.
Some of them are just boring and only used by clever fuckers, not normal people like you and me.
Really, you don’t need to know, it’s just me trying to impress. Most of the cycles on a CNC Lathe are wrongly call Canned Cycles. The correct name for a cycle like G76 Threading Cycle and G71 Roughing Cycle is a Multi Repetitive Cycle. No that’s not an illness it’s the correct name. So don’t start ringing the “no win no” fee lawyers.
That’s another piece of useeless information.
Haas and Some Fanucs
G76 X16.93 Z-25. K1.534 D.485 A60 Q0 P2 F2.5
X = Core diameter of thread
Z = Thread end point
D = Depth of first cut
F = Pitch of thread
You could write:
Fanuc
G76 P010060 Q20 R.02
P01 One spring pass 00 Chamfer 60 Thread angle
Q Minimum depth of cut
R Finishing allowance
X Core diameter of thread
Z Thread end point
P Depth of thread (as a radius no decimal point)
Q Depth of first cut no decimal point.
F Pitch of thread
Third two are the tool angle.
Fuck The Zeus Book
Lets Cut an M20 x 2.5 Thread Using The G76 Threading Cycle
Thread Depth =.614 x Pitch
.614 x 2.5 = 1.535
Have You Been Doing it Wrong for Years?
There are some absolute pricks out there claiming to know all about CNC Programming who actually know Jack Shit.
It is where the tool plunges into the thread and the cut gets wider and therefore is more prone to chatter as it deepens. It is going straight down the centre of the thread vee.
If you put in A60 then the cycle will flank cut.
Flank Cut?????
See below:
Don’t know what flank cutting is? Don’t worry it just means you are stupid. I won’t tell anyone, your secret is safe with me.
Help is At Hand
Ways to cut a thread
So Which One Is Best.
Why?
With method three you get a nice even cut with less chatter and less tool wear. It’s also kinder to your insert and better for the environment.
Is this you?
Come on now this is not good.
Wooppee It’s Easy
So on your calculator:
(1) Press keys for depth of the thread eg 1.534
(2) Press divide key (÷)
then press the √ key
1.534 ÷ √10 = 0.4854
D.485
So your cycle reads
- Enter the depth of thread (K Value).
- Press ÷
- Enter depth of first cut (D value)
- Press =
- Press the squared key (²)
The answer is:
10.01689871 that’s 10 to you.
So next time you cut a thread don’t guess the number of passes uses this formula it’s dead easy. You can also loose weight if you do this as part of a calorie controlled diet.
As in the example above.
(1.534 / .4854)²
1.534/.4854 = 3.1602
3.1602 x 3.1602 = 9.98737 (10 to you)
1.534 ÷√1 = 1.534 Cut = .000
1.534 ÷√2 = 1.084 Cut = .450
1.534 ÷√3 = 0.885 Cut = .199
1.534 ÷√4 = 0.767 Cut = .118
1.534 ÷√5 = 0.686 Cut = .081
1.534 ÷√6 = 0.626 Cut = .060
1.534 ÷√7 = 0.579 Cut = .047
1.534 ÷√8 = 0.542 Cut = .037
1.534 ÷√9 = 0.511 Cut = .031
1.534 ÷√10 = 0.485 Cut = .026
Some friendly Advice
Oh Yea Here Is Another Tip
When using G76 you can’t use feedhold. On some controls the tool will retract but please check the small print first or try it in fresh air.
A Few Rules
- Always use G97 speed in RPM you can’t use G96.
- Don’t move the Z start position unless it’s by a multiple of the pitch.
- Don’t change the speed.
- Machine has to accelerate into the thread so start at Z5. depending on the speed and pitch this may need to be more.
- Watch out for that Z end point. That’s the one that will make it hit the chuck if you get it wrong.
- Come and train with us.
Contact Us
13 Comments
Raffy P
October 21, 2019 at 5:38 amHi, Thanks for this post, everything works fine, however there is a factor which is not being controlled, The tool when going the rapid move out of the thread, it is touching the work piece, so it is making double thread ( main thread is getting messed up). Any suggestion how to solve this issue.
November 1, 2019 at 6:58 pmSounds like the start point is wrong. You need to start at a larger diameter
Gary Labbe
September 10, 2020 at 7:39 pmTrying to post a new comment but it won’t send
munna sharma
February 19, 2021 at 2:12 pm7 mm pitch 2start thread program i need
Clarita
December 18, 2021 at 10:34 amAn outstanding share! I have just forwarded this onto
a coworker who was conducting a little homework on this. And he actually bought
me lunch due too thhe fact that I found it for him… lol.
So let me reword this…. Thank YOU for the meal!!
Butt yeah, thanks for spending the time to talk anout this matter here on your
blog.
php patterns
December 20, 2021 at 4:21 pmSounds good makes it all worth while
Kevin Stallard
April 12, 2022 at 10:21 pmStep three of “Cut Depth” section appears incorrect. On one hand it says “1.534 / sqrt(10) = 0.4854 this is the value to enter for ‘K’ and the you show K.4854
But then in the next line you show the full gcode and the value for K is the thread depth 1.534 and then .4854 is used for D
I’m pretty certain I know which one is correct, but you might want to update the text here.
May 10, 2022 at 3:04 pmThanks for that it’s good to kow someone is concentrating. I’ve updated it. Thanks for reading and contributing
Asmaa Qassim
December 5, 2022 at 2:28 amThanks alot for helping me in my career
Steve
January 19, 2023 at 11:43 pmWhere does this formula come from for using the square root to determine the depth of successive passes? Why not just divide it up into equal sections?
Edvin Herrera
November 27, 2023 at 7:11 pmAny chance to have an example in inches like a 1/2-13 bolt
Afrouz
November 10, 2024 at 5:24 pmExample is for an external thread. Would you calculate X major diameter for an internal thread M20 * 2.5?
November 12, 2024 at 1:42 pmYes it would be 20mm
