G76 Threading Cycle
G76 Threading Cycle
Oh and It Gets Worse.
And not to mention all that boring maths that you will have to do. You remember that teacher with the beard that kept banging on about ratios and differentiation? Well, maybe you should have paid more attention.
Some of them are just boring and only used by clever fuckers, not normal people like you and me.
Really, you don’t need to know, it’s just me trying to impress. Most of the cycles on a CNC Lathe are wrongly call Canned Cycles. The correct name for a cycle like G76 Threading Cycle and G71 Roughing Cycle is a Multi Repetitive Cycle. No that’s not an illness it’s the correct name. So don’t start ringing the “no win no” fee lawyers.
That’s another piece of useeless information.
Haas and Some Fanucs
G76 X16.93 Z-25. K1.534 D.485 A60 Q0 P2 F2.5
X = Core diameter of thread
Z = Thread end point
D = Depth of first cut
F = Pitch of thread
You could write:
Fanuc
G76 P010060 Q20 R.02
P01   One spring pass       00   Chamfer        60   Thread angle
Q       Minimum depth of cut
R       Finishing allowance
X         Core diameter of thread
Z         Thread end point
P         Depth of thread (as a radius no decimal point)
Q        Depth of first cut no decimal point.
F         Pitch of thread
Third two are the tool angle.
G76 Threading Cycle
Fuck The Zeus Book
Lets Cut an M20 x 2.5  Thread Using The G76 Threading Cycle
Thread Depth =.614 x Pitch
.614 x 2.5 = 1.535
G76 Threading Cycle
Have You Been Doing it Wrong for Years?
There are some absolute pricks out there claiming to know all about CNC Programming who actually know Jack Shit.
G76 Threading Cycle
It is where the tool plunges into the thread and the cut gets wider and therefore is more prone to chatter as it deepens. It is going straight down the centre of the thread vee.
If you put in A60 then the cycle will flank cut.
Flank Cut?????
See below:
Don’t know what flank cutting is? Don’t worry it just means you are stupid. I won’t tell anyone, your secret is safe with me.
Help is At Hand
Ways to cut a thread
G76 Threading Cycle
G76 Threading Cycle
G76 Threading Cycle
So Which One Is Best.
Why?
With method three you get a nice even cut with less chatter and less tool wear. It’s also kinder to your insert and better for the environment.
G76 Threading Cycle
G76 Threading Cycle
G76 Threading Cycle
Is this you?
Come on now this is not good.
Wooppee It’s Easy
So on your calculator:
(1) Press keys for depth of the thread eg 1.534
G76 Threading Cycle
(2) Press divide key (÷)
then press the √ key
G76 Threading Cycle
G76 Threading Cycle
1.534 ÷ √10 = 0.4854
D.485
So your cycle reads
  1. Enter the depth of thread (K Value).
  2. Press ÷
  3. Enter depth of first cut (D value)
  4. Press =
  5. Press the squared key (²)
The answer is:
10.01689871 that’s 10 to you.
G76 Threading Cycle
So next time you cut a thread don’t guess the number of passes uses this formula it’s dead easy. You can also loose weight if you do this as part of a calorie controlled diet.
As in the example above.
(1.534 / .4854)²
1.534/.4854 = 3.1602
3.1602 x 3.1602 = 9.98737 (10 to you)
1.534 ÷√1   = 1.534      Cut = .000
1.534 ÷√2  = 1.084     Cut = .450
1.534 ÷√3  = 0.885     Cut = .199
1.534 ÷√4  = 0.767     Cut = .118
1.534 ÷√5  = 0.686     Cut = .081
1.534 ÷√6  = 0.626     Cut = .060
1.534 ÷√7  = 0.579      Cut = .047
1.534 ÷√8  = 0.542     Cut = .037
1.534 ÷√9  = 0.511      Cut = .031
1.534 ÷√10 = 0.485     Cut = .026
Some friendly Advice
Oh Yea Here Is Another Tip
When using G76 you can’t use feedhold. On some controls the tool will retract but please check the small print first or try it in fresh air.
A Few Rules
  1. Always use G97 speed in RPM you can’t use G96.
  2. Don’t move the Z start position unless it’s by a multiple of the pitch.
  3. Don’t change the speed.
  4. Machine has to accelerate into the thread so start at Z5. depending on the speed and pitch this may need to be more.
  5. Watch out for that Z end point. That’s the one that will make it hit the chuck if you get it wrong.
  6. Come and train with us.
Contact Us
Siemens Sinumerik Training
