Basic Turning
Basic Turning
G96 Hamsters Large wheel Small wheel
G97 Speed In RPM
G97 S1500 M3
When drilling  a hole you are on the centreline of the machine so you just want plain old simple RPM.
G96
G96 S200 M3
Basic Turning
If the tool was positioned  at a 100mm diameter it would be as if the tool were able to run around this diameter at  a speed 200 meters a minute.
Basic Turning
Neeeeeoooooooowwww
G96 G97 hamster on a Wheel
Anyway I did and his name was Harold Wilson (British Prime Minister at the time).
Basic Turning
G96 G97 all about hamsters
Harold Had G96
Harold Was a Clever Bastard
200 / .6864 = 291
Manual Lathe
cnc turning basics
G50 Warning
Watch the video
Basic Turning
G96 and G97
G96 Whoopee It’s amazing
So use G96 for everything.
Except for:
  • Drilling.
  • Tapping
  • Threading (Screw cutting)
  • Cutting the Lawn
Modal and non modal G codes
Let Me explain
We all know that programming can be complicated. So let me explain to you how it all works. This article explains the real meaning of Modal and non modal G codes.
Modal means that once a command is issued it stays in the control.
How Can you Actually Use This?
If you issue a G0 or G00 command the machine is in rapid and you do not need to re-state it.
Rapid means all motors are flat out, like a teenager in a Ferrari.
Every move from then on will be a rapid move unless you tell it otherwise. The G code that changes it must be in the same group. For example G0 G1 G2 and G3 are all in the same group a bit like The Beatles used to be.
The other day I was talking to  a “young person” who hadn’t even heard of the Beatles. I mean fuckin hell, am I really really old or are they doomed to be forgotten?
