Category Archives: Mazak Mill
CNC Milling G02 G03
CNC Milling G02 G03
Training Courses Let Me at Em
First in two halves
G0 X0 Y0 S1500 M3
G43 Z3. H01 M8
G1 Z-5. F100.
G41 X20. Y0 D1 F200.    (Apply Cutter Compensation)
G3 X-20. R20.                   (First Half)
X20.                                     (Second Half)
G1 G40 X0 Y0                   (Cancel Cutter Compensation)
G0 G53 Z0
G1 G41 X20. Y0 D1 F200.
G3 X20. Y0  I-20. J0 (Mill Full Circle)
G1 G40 X0 Y0
G3 I-20.         (Mill Full Circle….. Sooo Simple)
G1 G40 X0 Y0
G3 I-20. (Mill Full Circle)
I-20.        (Lets go round again)
G1 G40 X0 Y0
                D1 (Use offset 1)
                I20. (20mm Radius)
Know what I mean??
CNC Milling G02 G03
CNC Milling G02 G03
Now look at this.
CNC Milling G02 G03
CNC Milling G02 G03
CNC Milling G02 G03
CNC Milling G02 G03
Simple Full Circle Programme
G3 I-20.
G1 G40 X0 Y0
CNC Milling G02 G03
G3 I-20.    (The one on the left and the one we used)
G3 I20.     (The one on the right)
G3 J20.    (The top one)
G3 J-20.  (The bottom one)
Here They Are In Action
CNC Milling G02 G03
CNC Milling G02 G03
Click for More on G02 and G03
Call David
CNC Milling G Code List For Beginners
Download and print this nice large print CNC Milling G Code List
Download CNC Milling G Code List PDF
I always begin my training sessions by telling my students not to remember anything I say.
This sounds completely stupid and my excuse is it wasn’t my idea to say it.
About ten years ago I worked in France. After about a year and it seemed obvious that I would need to speak to people to order “Fish n Chips” and stuff like that.
Anyway I got these CD’s to teach me French and the bloke (can’t remember his name) started off by telling you not to remember anything he told you.
I think there is a bit of reverse psychology going on but the main idea is that you understand not remember. It didn’t work for me because I still managed to completely fuck up the language. Not realizing French Canadians speak differently to native Frenchmen (I was working for Bombardier) . Anyway I asked this bloke, in French, to “come with me”. I can’t remember what it is in French and after all the bloke on the CD had specifically told me not to remember.
Anyway turns out this had a sexual connotation and made me the complete laughing stock everywhere I went from then on. (I’ll let you do the maths on that one.)
“OK who bought all The fuckin toilet paper?”
When it comes to CNC Programming the idea of not remembering loads of G Codes is really important. Truth is you only need a few and it’s all about understanding what they do.
For Example I want to drill a hole.
You completed a training course at the CNC Training Centre. You understood it all and you practiced with you free simulation software that you get with the course.
You start writing a program to drill some holes.
From your training you know that there is a cycle that drills holes.
You understand how the cycle feeds the tool down to a depth and then it rapids out ready to do another.
Quick Fix G81 Video
You also know that if you keep adding more positions (X50. Y50.) it will keep drilling holes.
And… when you are sick of drilling holes there’s another G code to stops it.
What Are These G Codes?
So you just look em up on your CNC Milling G Code List.
G81 Drilling Canned Cycle
G80 Cancel Canned Cycle
Then you think “mmm I’m sure there’s one that pecks the material out and breaks it up”
“Let me see… Ah this looks like the one
G73                 Peck Drilling
Type up or print this list in nice big letters and stick it to the side of your machine
G00                 Move at Rapid speed
G01                 Feed in a Straight Line
G02                 Clockwise Arc
G03                 Counter Clockwise Arc
G04                 Time Dwell
G28                 Return Axis to Home
G41                 Cutter Compensation Left
G42                 Cutter Compensation Right
G40                 Cancel Cutter Compensation
G43                 Apply Tool Length Offset
G54 to G59     Work Offsets
G81                 Drilling Cycle
G73                 Peck Drilling
G83                 Deep Hole Drilling Cycle
G84                 Tapping Cycle
G80                 Cancel All Canned Cycles
G90                 Absolute Programming
G91                 Incremental Programming
CNC Milling M Codes List For Beginners
CNC Milling M Codes
List of M Codes for a CNC Milling Machine
Download CNC Milling M Code List
This is my list of CNC Milling M Codes and you will notice there aren’t many.
That’s because you don’t actually need many.
M Codes are used to turn things on and off on a CNC Milling Machine. Sometimes known as miscellaneous functions.
A typical M Code would be M03 which would start your spindle forwards.
M04 would be reverse and guess what?
M05 is stop the spindle.
There, you learned three already.
You don’t need the extra zero so I advise you leave it out, program M3 M4 M5.
It really doesn’t matter but….. You could be wasting memory space or wearing out the tips of your fingers.
Here’s what I think about leading zeros.
M codes are the Snow Leopards of CNC Machining
Snow Leopards are Solitary Animals
Snow Leopards only ever get together to mate, they don’t even have a Christmas party or get pissed on a stag night.
With M codes they hate being on the same line of code. If they are then they will fight to the death.
Tigers Playing
Please note no animals were hurt in the making of this post.
There are exceptions to this rule, M Codes that is, but please don’t overload yourself with this at the moment.
Just trust me.
The first one in the block usually wins but I can’t  guarantee it. So you could get some crazy shit happening.
G90 M8 G0 G54 X0 Y0 S1500 M3;
You wouldn’t even get an alarm on most controls and it may just obey the first M Code it sees and ignore the last one.
The other thing to note with M Codes is that it makes no difference where they are in a block of code.
So if you put your M Code at the front of a block of code.
M3 S1500 G0 X0 Y0;
Or the end.
G0 X0 Y0 S1500 M3 ;
The spindle will start according to the logic of the machine not where the M Code is in the block of code.
The Boring CNC Milling M Codes
That’s my list of M Codes the rest are really boring doing stuff like changing gear ranges and stuff.
Sorry I’m being flippant again.
CNC Milling M Codes Where Are The Rest?
Sorry you can’t have them. The reason for this is that they are different depending on what machine they are on.
CNC Milling M Codes
Hand Em Over
For example this beast is a Mazak Megaturn
CNC Milling M Codes
Mazak Megaturn
It Has a Gearbox.
To change gear you program M41 M42 and M43 for the different gears
M40 is neutral. Now on machines with gearboxes they do normally use these same M Codes.
However they can be different.
M10….. mmmm well that’s normally a clamp.
I think you get the picture. It is up to the machine tool builder.
It is best to get a specific set of M Codes from your machine manual.
The manual by the way is that book that nobody ever reads, it’s usually at the bottom of a bent up old filing cabinet.
Please Don’t Read It
I’ll read it for you then charge you a shit load of money for training.
Click here for CNC Training
Well Commented Programs
M11 (OPEN CHUCK)
M10 (OPEN CHUCK)
etc etc
I had a boss once who actually learnt sines and cosines of angles.
Cosines of Angles
Holy shit I mean it’s impressive and I must add in 1975 it was actually worth doing because we didn’t even have calculators.
Hope you enjoyed reading my article on CNC Milling M Codes.
G82 Drilling Program Example
X55. Y55.
X-55. Y55.
X-55. Y-55.
X55. Y-55.
Here is the CNC code
This is because of the G98.
Haas G82 example
X55. Y55.
X-55. Y55.
X-55. Y-55.
X55. Y-55.
G73 Peck Drilling Program Example
The G73 Cycle instructs it to drill a hole 17.5mm deep (Z-17.5) at a feed of 200mm per minute (F200.)
G73 Drilling Example
Haas G73 example
