More Heidenhain
Drawing Datum
On a Fanuc control it’s a G code usually G54 although as standard you have six of these.
G54 G55 G56 G57 G58 G59
Zero Return
X 0.000
Y 0.000
Z 0.000
What about Z you say?
Mazak Work Offsets
Toshiba BMC 800 Work Offsets
Is Six Enough?
Right Let’s Wrap This Up
So now if we program
Digital Readout
G57 H901
G0 X0 Y0
So Where’s This All Going?
Now then think about this.
Don’t Just Plonk It Anywhere
Now when you program.
G0 G55 X0 Y0
By The Way
There’s More
Lets Save Some Time
Doesn’t matter either.
Work Offset G54 G55 G56
And…
Heidenhain
Bridgeport Interact 412
This would call out offset 1.
Just zero the display.
How easy is that?
So there you go from Heidenhain on a Bridgeport Machine to Matsuura MX520 with a Matsuura G-Tech 31i control. There are loads of different machines but the principle is always the same.
Call David 07834 858 407
