Category : Fanuc Turn Haas Turn Mazak Turn New Stuff
Basic Turning
G97 Speed In RPM
G97 S1500 M3
When drilling a hole you are on the centreline of the machine so you just want plain old simple RPM.
G96
G96 S200 M3
If the tool was positioned at a 100mm diameter it would be as if the tool were able to run around this diameter at a speed 200 meters a minute.
Neeeeeoooooooowwww
Anyway I did and his name was Harold Wilson (British Prime Minister at the time).
Harold Had G96
Harold Was a Clever Bastard
200 / .6864 = 291
Watch the video
G96 Whoopee It’s amazing
So use G96 for everything.
Except for:
- Drilling.
- Tapping
- Threading (Screw cutting)
- Cutting the Lawn
- Fanuc control training.
- Fanuc training courses
- CNC lathe training
