Fanuc Subprogram (Local Subroutine)
If you have ever used local subroutines on Heidenhain or Yasnac. Then you will know how convenient it is to save all your programs in one go. No need to remember to save all those shitty little external sub programs.
What’s He On About?
If you are now saying “what the fuck is he on about”. Here is an explanation.
A local subroutine or subprogram is where you stuff all your subprograms at the end of your main program.
So on a Fanuc control if you were making this part below.
Drill spot drill then tap.
Fanuc Subprogram
Programme would look like this.
Fanuc Subprogram
Thing is the code is just repeated three times. I have nice round numbers in here like X40. and Y20. so it’s easy to notice mistakes. But if it was X40.392 for example you wouldn’t spot a slight mistake.
So if you call a subprogram it looks like this.
Fanuc Subprogram
And then your Subprogram is like this.
Fanuc Subprogram
Fanuc Subprogram
The M98 P500 calls the external Fanuc Subprogram. Read this if you don’t know about sub programmes.
Saves you having to repeatedly write shit loads of code.
So that’s why we use a Fanuc Subprogram. But……
You have to look after these bloody things and they seem to be able to just get lost on their own.
You find them at the back of the fridge sometimes along with a piece of mouldy old cheese. At least you can make a meal of the cheese.
Fanuc Subprogram No More Lost Programs
So this is how it looks with a Local Subroutine.
All you need to do is replace P with Q. So mind your P’s and Q’s as they say.
The Q corresponds to any N number. So you could have loads of these stacked up at the end of your programme and you only need to save it once. All this shit will go with it and you don’t need to worry about it ever again.
Haas To The Rescue
Of course Mr Haas sorted this out years ago with M97, this calls a local sub. M98 calls an external program. It’s on all Haas machines and you definitely do need to fuck with any parameters.
Just A word Of Caution.
There are PARAMETERS involved. Arrrrrrrrrrrh……..the dreaded PARAMETERS
To call a subroutine on your Fanuc control. You first need to make sure that Bit 0 of parameter 06005 is set to 1
Fanuc Subprogram
It’s only on the newer controls by the way.
Sub programs on a Siemens control.
Thanks For Reading My Articles We Love you all .
Ten Things You Might Not Know About The Fanuc Sub Program
Sub Program Fanuc
Here are ten things you might not know about Fanuc sub programs,
Fanuc CNC controls are the most common controls in the world so it might be useful to have a good understanding of how sub programs are called and used.
(1) You Can Call a Sub Program By Name.
Yes you heard it here the program can be called by it’s name or it’s number. When calling by name don’t use the P.
Just put the name of the program in these things <> with an M98 and your away.
M98<ALBERT>
The only problem with this is that the syntax needs to be spot on so if you have got complicated names for your your sub routines then you might be in the shit.
I always call mine names like ALBERT that are easy to remember.
(2) You can use internal sub routines on a Fanuc Control.
Some people call these local sub programs. It just means it’s tagged on the end of your program which makes them nice n easy to look after. A bit like a pet Goldfish or a pet fly.
I bought mine from the local pet store. I asked the assistant if he sold pet flies and he said no. I said “well there are loads in the window”.
Anyway he sold me one (£15) his name is Paul
This is not him this is Steve.
Internal Sub-Routines
By typing M98 Q500 your control will look for N500 within your current program. This is great because you can add the sub programs to the end of your main program. Don’t forget to leave big gaps so you can clearly see where and what they are. Oh and mind your P’s and Q’s.
M98 P500 (Call O500 externally)
M98Q500 (Call N500 in main program.
Oh and read this too.
Sub Program
Just one other thing. Watch your n numbers it’s easy to get them mixed up. Try and use a convention.
