Retain Geometry Fanuc Parameter 5003
Retain Geometry Fanuc Parameter 5003, to change this parameters first you need to go to the setting screen in MDI.
Today we are going to change the parameter that stops your tool offset from being dropped when you press reset.
Parameter 5003 will stop that annoying thing where you activate a tool offset and then press reset and it clears.
If you have a Mazak machine you will know that if you index to tool 6 the offset will be instantly activated. This means if you are on a CNC Lathe you can just move the tool to a 50mm diameter and turn away. Providing the tool has been measured the size will be correct.
You are probably used to the tool not being active if you use a Fanuc control but help is at hand.
With this parameter 5003 set to 1
You input T0101 in MDI and that activates tool number one’s offset. Your position display is now correct (allowing for tool geometry).
If you now look at the ABSOLUTE position display and press reset it will not change. If it changes then the machine is more than likely dropping the tool geometry.
#6  (LVK) Set to 1 not cleared on reset
#7 (TGC) Set to 1 not cleared on reset
Bits n Bobs
Other Parameters Of Interest
1300 Stops over travel alarm
3101 Clear Screen
3102 Unlock Programs
3203 Clear MDI Screen
