Heidenhain Sections, I don’t get to work on Heidenhain controls anywhere near as much as I would like to.
A recent training program we undertook with a packaging company meant I got loads of time to have fun with this control whilst working with some fantastic people oh, and I got paid too.
Ever since I first worked on Heidenhain controls in the early 80s I have found them very intuitive. As with all the CNC controls (and I am gonna have a moan) they tend to get over complicated.
Heidenhain circular interpolation, mm what bullshit, this just means cutting in a circular move.
Very often wrongly called interpolation here is Wikipedia meaning.
Well that’s definitely confused me. But to me interpolation means movement.
Circular interpolation moving in a circular motion, full or part circle.
Linear interpolation moving in a straight line.
Heidenhain circular interpolation, there are four ways to produce a circular move on a Heidenhain control. You will love the flexibility of this control once you take the time to get to know it.
CNC Airfryer
Heidenhain is the Air-fryer of CNC controls, it does the lot and in many different ways. Now the healthy option is the one that suits your drawing and require the least amount of Maths.
Ok sorry to shroud you in a cocoon of total bullshit.
It’s like Macro on a Fanuc Control. What you do is you program a circle and instead of putting numbers for the X values n stuff you put a Q number like Q1 or Q10
Then you tell it what the Q values are. So instead of X-20. you could have X+Q10
If you then went on to define Q10 as -20 then X would be X-20.
All will be revealed.
Take a look at this code.
Full Circle Heidenhain
This code will mill a full circle and because it’s in incremental (note the I in front of the X value) you can dump one anywhere. By that I mean you can mill one of these circles anywhere not take a shit anywhere.
Now watch it in action.
This is great but it is not easy to control. If we wanted a different diameter there are quite a few figures to change. If you are a bit of a prick like me then you’d probably get it wrong and scrap the part.
Q DEF To The Rescue Full Circle Heidenhain
Using Q def is really easy. You could start by using it to change the feedrate. Look at the code now.
Line 7 and line 17 define Q1 as two different values.
So when each one calls LBL 1 the feedrate in line 25 will change to whatever value is in Q1.
Clever eh…..
But that’s not all.
You can have loads of Q values whopeeee.
Stick Around For The Exciting Stuff
Watch this before you ditch this post and go on Facebook and see what your mate Pete had for his breakfast. Or “oh look at this the dog just crapped on the new sofa”
So, you’re with me….
Lets do the same but this time replace the X value. (Oh and some other shit too like the Z Depth)
This macro uses Q Values to externally control the radius, feedrate and depth of a circle.
Because the program is in incremental you can place it anywhere you want.
I have purposely kept it really simple for demonstration purposes (not because it’s all I know).
So you replace the X values or whatever you want to control with Q Numbers.
