G82 Drilling Program Example
X55. Y55.
X-55. Y55.
X-55. Y-55.
X55. Y-55.
Here is the CNC code
This is because of the G98.
Haas G82 example
2 Comments
Bhavesh Patel
August 24, 2020 at 4:24 am
Thank sir
Bhavesh Patel
August 24, 2020 at 4:25 am
Thank sir
Very nice
