A Canned Cycle What is It?
If you want to learn CNC programming then you need to know what a canned cycle is.
In a Can…….
X60.
X70.
X80.
X90. Y60.
Want to know More?
Anyway Here are a few:
G98 G99
G43 Z50.H1 M8
X60.
X70. G99
X80.
X85. G98
X90. Y60.
Why you ask?
Easy you can jump over shit.
It Gets Better.
X60.
X80.
X90. Y60.
Now let’s alter the feed
X60. F300. (Change feed)
X70.
X80.F200.(Change it back)
X90. Y60.
Do’s And Don’ts
Do Not………
X60.
X90. Y60. (ETC)
Do Not Repeat Axis Moves.
X60. Y50. (Don’t need Y50.)
X70.
X80.
X90. Y60.
D0…….
- Always use a canned cycle if possible it saves loads of time. It is also really easy if you need to edit anything.
- Make your CAD/CAM system output canned cycles, not long hand code. I saves loads of time if you need to edit.
- Love engineering and be nice to your cat.
Quite simple but 31.63 added up nine times? Mmmm I never learned my 31.63 times table.
O0001(Drill and Tap M10)
T01 M06 (20mm Spot Drill)
G90 G0 G54 X0 Y0 S1500 M3
G43 Z3. H1 M8
G81 G98 Z-10. R1. F100 L0
G91 X-31.63 L9
G0 G53 Z0
ETC
- The programme moves to the datum X0 Y0 which is the middle of the part at the right hand end.
- The G81 has an L0 at the end. L0 is not a Lionel Richie song it just means don’t do one. So it moves to X0 Y0 and does nothing.
- The next line, G91 means incremental move so it moves incrementally nine times (L9) X-31.63 and drills a hole each time.
