Training Course Fanuc Haas Macro Programming
Fanuc Training Onsite
Call David : 07834 858 407
(Suitable for Fanuc, Mazak and Haas Macro Programming)
Duration:          2 days.
Times:               Start 9.30am Finish 4.00pm
Apply Now
Price £300 per day
Total £600 2 days
  • Macro CNC Programming Fanuc
  • Macro CNC Programming Haas
  • Macro CNC Programming Mazak
Most ISO type controls that have Macro use a very similar system.
Once you have grasped the concept of parametric programming you will find Heidenhain Q parameter programming easy to figure out.
Suitable for Fanuc, Mazak and Haas Macro Programming Lathe and machining centre
Haas, Fanuc or similar controls (ISO Mazak).
Haas Macro Programming   Haas Macro ProgrammingHaas Macro Programming
Make sure you have the Macro option on your control, it’s a real disappointment when you get all excited about this only to find you don’t have the option. Remember if you have a touch probe you will almost definitely have Macro installed on your machine.
What Use Will it Be?
Write your own canned cycle
Yes you always dreamed of having your own personal G code, you can’t call it like Bill’s G code or something but you may have G271 or something which is personal to you.
Make A Set of Similar Parts
Imagine you had a bunch of parts that were similar, maybe the same holes but in different positions or a similar shape.
You could write a parametric (Macro) programme that would be completely adjustable and would make them all instead of having to keep writing similar programmes.
You can build these programmes and add to them as you get better and better and your ideas flood in.
I always say to students to start simple and build on your experience. Just using Macro in its simplest form will inspire you to go on to do greater things.
Interrogate Your CNC Machine
  • Spindle Speed.
  • Position.
  • Datum.
  • Tool Length.
  • What tool is in the spindle.
  • Put the machine into an alarm state when things go wrong like wrong data is input.
  • And loads more.
Do Calculations
  • Simple trigonometry.
  • Calculate feeds and speeds.
  • Simple maths.
  • Input formula and get answers.
What Skills Will I Learn
  • Basic use of variables
  • Creating simple Macro programmes
  • How system variables work
  • How to write probing Macros
  • Creating your own G Codes
  • Create alarms to make sure your Macro users behave
  • Practical use of Macro
  • Creative use of Macro
  • and more, loads more
