Edgecam Move Part
Edgecam Move Part
It is really annoying when you simulate a part and you can’t figure out why Edgecam is showing a collision and you don’t know why.
When using the ROUGHING CYCLE it is important to tell Edgecam that the tool is centre cutting as this will change the cutter path.
Tick this box if the cutter is centre cutting. Most modern endmills do cut on centre so you can plunge them down.
It’s important because if you get this wrong in the real world the cutter will get very hot!
Roughing Edgecam
Centre Cutting Tool
If you want to buy Edgecam contact us 07834 858 407
Siemens Sinumeric Training
Edgecam Add Stock
CNC Programming Using CAD/CAM
CNC Programming, When will it not be needed?
Are we fast approaching the day when we don’t need to know anything about CNC Programming in terms of G code etc.
CNC Programming
Tool Holder (Patent Pending)
Short answer is yes.
I was watching an interesting video on youtube the other day. This guy (seemed like a very clever guy) had bought an old CNC Lathe, a Mori Seiki.
I don’t think he had ever done any machining or general metal work type stuff.
His approach was untainted shall we say. He’d certainly never done any G code type CNC Programming.
CNC Programming
He immediately looked for software which would program this machine and said how in the past it would have been programmed with G code by hand.
Anyway he got something like One CNC or Fusion 360 and created a program. He went on to produce quite a few parts.
Really this proves that you don’t need to know G Code programming, or does it?
Because I am an old dinosaur and I make a living partly from teaching people G code type CNC Programming, I wonder if people like me are clinging on to these old skills and not moving forward.
It reminds of the times when CNC’s were first introduced all the old guys used to say they would never replace the capstans and autos. I remember my dad beating my first chess computer and saying it was just a gimmick.
CNC Programming
So what problems do you get when programming straight from software. Actually if you know what you are doing the answer is none. But do you know what you are doing?
The danger is when the person using the CAM system doesn’t really understand about work-holding and tooling.
I bet the aforementioned guy had some serious problems with his selection of cutting tools.
Edgecam Training
Edgecam Training Call David: 07834 858 407
Edgecam Classroom Training
This two day course teaches you to program from a basic part in Edgecam right through to machining on a real machine.
Learn to create a CNC program from lines or a solid model then post out the code you can then run it on a real CNC Lathe or Milling machine.
This course is designed to get you using Edgecam in the real manufacturing world.
The course is at our training centre in Nottingham, England
Apply Now Edgecam Turning
Apply Now Edgecam Milling
For more details or for on-site CNC Machine training
Call David  on :07834 858 407
Edgecam Onsite Training
Edgecam Articles
Layers in Edgecam
Edgecam Version Update Now
