CNC Turnkey Solutions
CNC Turnkey Solutions, CNC Training Centre specialise in delivering large and small turnkey solutions.
Contact David: 07834 858 407
CNC Turnkey Solution can be full or part solution.
From receipt of a part to be machined, right through to a fully operational solution.
  • Fully model and simulate agreed solution using Edgecam and Inventor.
  • Procure machine tool.
  • Procure fixtures and tooling.
  • Programme and prove out
  • Final inspection.
  • Train operators.
  • Project handover.CNC Turnkey Solutions
In this engineering world of skill shortages CNC Turnkey Solutions are more and more prevalent.
You may want a complete solution:
  • Machine.
  • Tooling
  • Fixtures.
  • Programmes.
  • Training.
  • Handing over a fully operational part in production.
You may just need part of the solution, maybe you already have a machine to use for the project.
In the attached video it shows a very simple turnkey which we supplied to a customer.
Although we have undertaken many much larger projects this one is in my opinion one of the most difficult. I don’t know who said it and I can’t find the quote but it is much easier to design a supercar then it is to design a cheap family saloon and that’s because of strict design a budget constraints.
This project epitomised that because they needed to produce simple parts in volume. The budget was tighter than a….. Well you know the rest.
We were proud to come up with this super fast loading simple fixture (watch the movie)
Everything is tested in the virtual world before cutter comes within a mile of steel. Loads of discussions can pass to and fro (screencasts, videos even good old fashioned phone calls). This means the final solution is already tried and tested. The solution works straight out of the tin. (Or should that be does what is says on the tin).
Workholding devices (design and manufacture of jigs and fixture). Pneumatic or hydraulic clamping systems.
