M Code Alias Fanuc Parameter 6080
Category : Fanuc Parameters
M Code Alias Fanuc Parameter, to change this parameter you need to go to the setting screen in MDI.
Today children we are going to change the parameter that allows us to alias an M code to a 9000 series program.
Bits n Bobs
Alias What the fuck is an Alias?
Well to use an alias you have to know a bit about Macro programming
Now if you don’t it’s probably going to be best if you go and play with your Xbox.
But if you do know about macro (and you don’t need to know much).
It means you can write a program to do something and use your own special M code to call it.
So for example if you were to put 384 in parameter 6080.
If you program M384 you would be directed to program 9020.
Parameter 6080 is the M code for program 9020
Parameter 6081 is the M code for program 9021
Parameter 6082 is the M code for program 9022
Parameter 6083 is the M code for program 9023
Parameter 6084 is the M code for program 9024
Parameter 6085 is the M code for program 9025
Parameter 6086 is the M code for program 9026
Parameter 6087 is the M code for program 9027
Parameter 6088 is the M code for program 9028
Parameter 6089 is the M code for program 9029
Now program 9020 could look like this.
09020 (M384 Macro)
M9 (Turn off Coolant)
M5 (Stop Spindle)
G40 (Cancel Cutter Compensation)
G80 (Cancel Canned Cycle)
G90 (Absolute)
G0 G53 X0 (Return X To Tool change Position)
G53 Z0 (Return Z To Tool Change Position)
(Any Old Shit You Want to Do)
So when you program M384 in MDI or from a program it jumps into program 9020 and does all that lot.
There is just no end to the stuff you can do with this. I’m not telling you anymore cos I need the work and probably couldn’t handle the competition.
Oh Yea By The Way
If you want to learn macro programming look no further.
