Category : Haas
Reposition Haas  Mid-Program
Piss easy.
Reposition Haas
Same Shit different Day
Here We Go
Reposition Haas
Reposition Haas
Do whatever you want to do.
  • Inspect the part.
  • Blow the hole out.
Now go back into memory mode.
Press Cycle Start.
Reposition Haas
Then axis.
And bang away you go.
The program continues.
1 Comment
cristi
November 2, 2019 at 7:43 pm
whattttttt?????????????? I’ll try that !!!
CNC Training Centre
