G71 Haas (Single Line)
page g71                                                     G70G71Picture
Multi repetitive cycles like G71 and G70 make programming without CAD/CAM so quick and easy.
When you rough and finish turn your CAD CAM system will probably pump out enough CNC code to bring down the GCHQ website.
You might say “so what my machine has a huge memory”. That is until you want to edit the number of cuts. It’s back in the office edit, edit, pump out code and back to prove out.
The CAD CAM salesman will tell you not to edit on the machine, sorry mate I live in the real world where that is almost impossible.
So until we get there, compromise.
Use rough and finish cycles then it’s dead easy to edit on the machine. Even better do some work on the Post and get the CAD CAM to pump out rough and finish cycles for you.
This video covers the one line and the two line versions of G71 explaining the differences. Originally Fanuc CNC controls used just a one line display then they changed to two lines.
Watch my video on how to use G71 and G70.
  • Fanuc programming training.
