Clear MDI Screen Fanuc Parameter 3203
Clear MDI Screen Fanuc Parameter, to change this parameters you need to go to the setting screen in MDI. Now put a 1 in the parameter write box.
Today we are going to change the parameter that allows us to clear the MDI screen by pressing reset.
Fanuc Parameter
Parameter 03203 Bit 7 (MCL)
If you set parameter 3203 BIT 7 (MCL) to a 1 then when you press reset your MDI screen will be cleared.
Ever thought how annoying it is when you want to do a tool change and you type
T01 M6;
M30;
Then later you want to do the same thing but the MDI screen has cleared. Help is at hand.
This was me in fancy dress when i was younger.
Anyway all you need to do is tinker with bit 7 (#7)
That means it will either clear when you press reset or just stay there waiting for you.
Please note you will need an M30 at the end of your MDI program for this to work.
Bits n Bobs
1300 Stops over travel alarm
3101 Clear Screen
3203 Clear MDI Screen
Visit this guy if you don’t have a manual.
1 Comment
Nasr Lotfy
June 22, 2020 at 4:10 am
Dear friend, I have very important and very urgent question ?
I have a turning machine control type ( FANUC Series Oi Mate – TC ),
But the ( MDI ) key mode if I press key ( MDI mode ) does not work,
Are you have any other way to activate ( MDI ) mode at I Can change PARAMETER or other operation for machine ?
